black_sedan Posted August 22, 2007 Report Share Posted August 22, 2007 I am going to install the D3 and was wondering where the VSS wire is located on my vehicle and also, what other out of the norm wire will I also have to hack into?? Quote Link to post Share on other sites
titos Posted August 22, 2007 Report Share Posted August 22, 2007 Speed Sense blue/white ECM/PCM Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26. On the 6 cylinder models it is in the gray connector A, pin 11. Brake Wire white/black + brake pedal switch Parking Brake green/orange - top of fuse box, large white plug Radio 12v white/green + radio harness Radio Ground black - radio harness Radio Ignition yellow/red + radio harness Radio Illumination red/black + radio harness Factory Amp Turn -on N/A Power Antenna yellow/green + radio harness LF Speaker +/- green/black - lt. green +, - radio harness RF Speaker +/ - green/yel - gray or gray/red +, - radio harness LR Speaker +/ - blue/white - blue/black +, - radio harness Notes: On some models the LR speaker wires are blue - pink. RR Speaker +/- pink - blue/yellow +, - radio harness Notes: On some models the RR speaker wires are lt. green - purple. hope this helps Quote Link to post Share on other sites
black_sedan Posted August 22, 2007 Author Report Share Posted August 22, 2007 thanks for the response. for the 4cyl model, it says its on the passenger side. what do i start taking apart and look for? also, where is the brake wire? do i even need to connect the brake wire? Quote Link to post Share on other sites
vicn77 Posted August 23, 2007 Report Share Posted August 23, 2007 there should be a plastic panel (triangular in shape) that you can remove that's connected to the center console on the passenger side. once you've removed that you will see the ecu (ecm, pcm whatever you call it). the wires will be there you might have to pull the carpet a little to get to the wires. as for the brake wire why don't you just do the bypass you will need to ground the brake wire. food for thought, if you are using the OEM kit for the replacement pocket underneath the factory radio, you will need to play with the mounting brackets as if you don't the radio will start out pretty far and you will not be able to use the pioneer dash trim (if not used you will have gaps on the sides, but an easy way to stash money and coins...could be used as a piggy bank!) Quote Link to post Share on other sites
black_sedan Posted August 24, 2007 Author Report Share Posted August 24, 2007 thanks for your post! it is greatly appreciated! it helped me out a lot! thanks again Quote Link to post Share on other sites
accelerated Posted August 2, 2010 Report Share Posted August 2, 2010 I want to connect an amp and subs to a 06 accord with nav. Can I connect the LOC to the factory sub wires? What is their +/- color code? Quote Link to post Share on other sites
