whitelightning74 Posted September 6, 2007 Report Share Posted September 6, 2007 I have a 2005 f250 which runs two batterys and after having my d3 installed and i got the blue tooth and the ipod adapter. Now my truck batteyr is dying when you leave it sitting a lil while and go to start ot it wont harldy start. What can be draining these two batterys so quick. Could it be the blue tooth Quote Link to post Share on other sites
idbl_fanatic Posted September 6, 2007 Report Share Posted September 6, 2007 are they stock 2 batts? if not do you have the isolated from one another? or if not, at least are the they same type, brand? Quote Link to post Share on other sites
Itchy Posted September 6, 2007 Report Share Posted September 6, 2007 you'll want to verify the accessory wire from the d3 and possibly BT (can't remember it BT has that wire), is not connected to a constant hot feed. Quote Link to post Share on other sites
MisFit Posted September 7, 2007 Report Share Posted September 7, 2007 bluetooth doesnt get hooked to accessory, it gets hooked to constant. are you sure you didnt mix up the hot and accessory wires? Quote Link to post Share on other sites
Kiki's Ring Posted September 25, 2007 Report Share Posted September 25, 2007 Did you get this worked out?? I'm considering adding a Bluetooth adapter to my F-250 Desiel. What was the resolution?? Quote Link to post Share on other sites
