Dan4flying Posted January 28, 2015 Report Share Posted January 28, 2015 Is there anyone out there using a Galaxy Note edge on their NEX unit? If so did you have to root your phone? I am currently using the 8000nex with a galaxy s5. Both are running kitkat but I am unsure if there will be any hardware issues. I do not want to drop money into the Note Edge if it is not going to work. Thanks Quote Link to post Share on other sites
onebyside Posted January 29, 2015 Report Share Posted January 29, 2015 bluetooth is bluetooth nowadays Quote Link to post Share on other sites
Dan4flying Posted January 29, 2015 Author Report Share Posted January 29, 2015 Thank you for the reply. The bluetooth connection is not what my concern is. To mirror my phone using appradio I have to use the HDMI out of the unit to a Samsung MHL adapter. It is that functionality I am concerned about. Quote Link to post Share on other sites
Dan4flying Posted January 29, 2015 Author Report Share Posted January 29, 2015 bluetooth is bluetooth nowadays Thank you for the reply. The bluetooth connection is not what my concern is. To mirror my phone using appradio I have to use the HDMI out of the unit to a Samsung MHL adapter. It is that functionality I am concerned about. Quote Link to post Share on other sites
Jak Crow Posted February 9, 2015 Report Share Posted February 9, 2015 If the Note Edge acts anything like the Note 4, the AppRadio app or the 8000 isn't compatible with it at this time. Running AppRadio on my Note 4, both stock and rooted firmwares, the AppRadio app doesn't recognize the 8000's touchscreen. I've also tried the Note 4 with AR Unchained Reloaded and the screen is squished instead of displayed in the proper aspect ratio, but at least the 8000's touchscreen works with it. Quote Link to post Share on other sites
RRSpikes Posted February 9, 2015 Report Share Posted February 9, 2015 If the Note Edge acts anything like the Note 4, the AppRadio app or the 8000 isn't compatible with it at this time. Running AppRadio on my Note 4, both stock and rooted firmwares, the AppRadio app doesn't recognize the 8000's touchscreen. I've also tried the Note 4 with AR Unchained Reloaded and the screen is squished instead of displayed in the proper aspect ratio, but at least the 8000's touchscreen works with it. It's not the app or the radios, it's a Samsung thing. Use an alternative launcher and the problem will be solved. Quote Link to post Share on other sites
Jak Crow Posted February 10, 2015 Report Share Posted February 10, 2015 It's not the app or the radios, it's a Samsung thing. Use an alternative launcher and the problem will be solved. I've used different launchers and have gotten the same result. If you specifics, please share. Quote Link to post Share on other sites
RRSpikes Posted February 11, 2015 Report Share Posted February 11, 2015 Hmm, if you have an alternate launcher installed and have adjusted the image size (page 112 of manual) then you should be good to go. I use Nova on my Note 4 & Note 4 Edge. I use Apex on my S5. Quote Link to post Share on other sites
Tango_6 Posted February 13, 2015 Report Share Posted February 13, 2015 I am planning on getting the Note edge or the S6 edge. I am glad this thread was started. Quote Link to post Share on other sites
Dan4flying Posted June 2, 2015 Author Report Share Posted June 2, 2015 Just an update to my initial question. I currently have a note edge and there is a appradio update available. Everything works great now with no problems yet. Quote Link to post Share on other sites
Jak Crow Posted June 2, 2015 Report Share Posted June 2, 2015 I'm shocked. SHOCKED I tell ya, that Pioneer has put out an update to address the high res phones. It's only been 7 months too. Quote Link to post Share on other sites
