Upgrading NEX4000 to NEX4100 - Work in Progress
  • Replies 623
Ok so update here. I was able to modify the script to break apart and resign the android boot.img. I used this to modify the init.rc to add the sdcard0 logging that AdamOutler recommended. However, that logging never shows up on the sdcard, although it does seem on boot that it is waiting for something.
It is good to note that the script below should only be used to modify the 8100 Firmware for now, as it contains the headers for such. Eventually we can make the script more compatible, but we need it to help us fix one deck first.
Also to be clear, I used the script to modify the 1.03 8100 firmware, then renamed it to load on the 8000 NEX, where no logging showed up on the sdcard when it should have.
#! /bin/bash
# AVIC.sh - Unpacks SYSTEM.img from the AVIC firmware for modification, waits for an input, then repackages.
# THIS FILE AND DERRIVITIVE WORKS ARE SUBJECT TO ALL TERMS OF LICENSING BELOW!
# License:
# Term 0: If you modify this file, you must share any changes with the file creators and/or publicly on AVIC411.com
# Term 1: If you find a new use, share changes on AVIC411.com
# Term 2: If it worked say thanks.
# Term 3: IF anyone claims this is black magic, I'm going to flip.
# By bass_rock http://avic411.com/index.php?/user/116652-bass-rock/
# Heavily modified by AdamOutler adamoutler@gmail.com
# http://avic411.com/index.php?/topic/80945-upgrading-nex4000-to-nex4100-work-in-progress/page-19#entry332704
# Modified by bass_rock to edit the kernel and only to be used on the 8100 for now
#this function is called when system is not Linux, user is not root, or user did not specify a file
usage() {
  echo "usage:"
  echo "  AVIC.sh /path_to/firmware.zip [AVIC Model] [AVIC firmware version]"
  echo "where AVIC Model = 5000, or 8100"
  echo "where AVIC firmware version = 140 or 150"
  echo "make sure that mkbootimg is in a folder mkbootimg_tools next to this script"
  exit
#exit on any error
set -e
#verify system is Linux and user is root and specifed a file
test "$(uname)" = "Linux" || $(echo "this only works on linux" && usage)
test $(id -u) -eq "0" || $(echo "you must run as root" && usage)
test -z "$1" && $(echo "you must specify a file" && usage)
#set variables for use (default AVIC-5000NEX, Version 140)
AVICZIP="$1"
m=$2
model=${m:="5000"}
v=$3
version=${v:="140"}
#create absolute paths for reference
workdir=$(pwd)"/work"
imageDir="$workdir/AVIC${model}NEX/PLATFORM"
SYSTEMmount="$workdir/AVIC${model}NEX/PLATFORM/SYSTEM"
#set up file and extract properly
mkdir -p $workdir/
unzip -o "$AVICZIP" -d $workdir/
cd "$imageDir"
#remove header from image
dd if=PJ${version}PLT.PRG of=PJ${version}PLT.IMG bs=512 skip=1
dd if=PJ${version}PLT.PRG of=PJ${version}PLT.HEADER bs=512 count=1
#ignore errors while we create a new folder for working with image
set +e
umount "$SYSTEMmount" 2>&1
test -e "$SYSTEMmount" && rm -rf "$SYSTEMmount"
mkdir $SYSTEMmount
set -e
#mount the image
mount PJ${version}PLT.IMG "$SYSTEMmount"
echo "You can now modify the img located in"
echo "$SYSTEMmount"
read -n 1 -p "Press any key to continue" isdone
sync #ensure all changes are written to disk
defaultheader="00060301010000000100000000000000504A313530504C5402100000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"
#get image size
# for mac
# SIZE="$(stat -f%z PJ${version}PLT.IMG)"
#for linux
SIZE="$(stat -c%s PJ${version}PLT.IMG)"
echo "IMG size is: $SIZE"
#We have to swap the hex values from big endian to little endian cause the NEX is arm.
UNSWAPPEDHEXSIZE="$(printf '%x\n' $SIZE)"
vSIZE="$UNSWAPPEDHEXSIZE"
SWAPPEDHEXSIZE="${vSIZE:6:2}${vSIZE:4:2}${vSIZE:2:2}${vSIZE:0:2}"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.IMG)"
vCRC="$UNSWAPPEDHEXCRC"
SWAPPEDHEXCRC="${vCRC:6:2}${vCRC:4:2}${vCRC:2:2}${vCRC:0:2}"
echo "Unswapped size hex is: $UNSWAPPEDHEXSIZE"
echo "Swapped size hex is: $SWAPPEDHEXSIZE"
echo "Unswapped crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped crc hex is: $SWAPPEDHEXCRC"
#create new header
perl -e "print pack 'H*', 'A55A5AA5${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}${defaultheader}'" > PJ${version}PLT.HEADERNEW
cat PJ${version}PLT.HEADERNEW PJ${version}PLT.IMG > PJ${version}PLT.PRG
rm -rf PJ${version}PLT.IMG
rm -rf PJ${version}PLT.HEADERNEW
defaultheaderver="A55A5AA5C00000000006030101000000010000002C000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF010000000100000050004C004100540046004F0052004D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000050004A0031003500300050004C0054002E005000520047000000000000000000000000000000000000000000000000000000000000000000"
SIZE="$(stat -c%s PJ${version}PLT.PRG)"
echo "PRG size is: $SIZE"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.PRG)"
echo "Unswapped prg size hex is: $UNSWAPPEDHEXSIZE"
echo "Swapped prg size hex is: $SWAPPEDHEXSIZE"
echo "Unswapped prg crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped prg crc hex is: $SWAPPEDHEXCRC"
perl -e "print pack 'H*', '${defaultheaderver}${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}A55A5AA5'" > PJ${version}PLT.VERSTART
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.VERSTART)"
echo "Unswapped verstart crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped verstart crc hex is: $SWAPPEDHEXCRC"
perl -e "print pack 'H*', '${SWAPPEDHEXCRC}'" > PJ${version}PLT.VERSTART1
cat PJ${version}PLT.VERSTART PJ${version}PLT.VERSTART1 > PJ${version}PLT.VER
rm -rf PJ${version}PLT.VERSTART
rm -rf PJ${version}PLT.VERSTART1
rm -rf ../PJ150PLT.VER
mv ./PJ150PLT.VER ../PJ150PLT.VER
cd "$workdir"
#Lets modify the kernel now
dd if="$workdir/AVIC${model}NEX/BOOT/PJ${version}BOT.PRG" bs=512 skip=1  of="$workdir/AVIC${model}NEX/BOOT/boot.img"
#dd if="$workdir/AVIC${model}NEX/RECOVERY/PJ${version}REC.PRG" bs=512 skip=1  of="$workdir/AVIC${model}NEX/RECOVERY/recovery.img"
cd "$workdir/AVIC${model}NEX/BOOT"
abootimg -x boot.img
echo "Renmove the boot size in bootimg.cfg"
"$workdir/../mkbootimg_tools/mkboot" ./boot.img ./newUnpack
echo "You can now modify the ramdisk in"
echo "$workdir/AVIC${model}NEX/BOOT/newUnpack"
"$workdir/../mkbootimg_tools/mkboot" ./newUnpack ./newBootImage.img
#Lets work with the boot one first.
rm -rf "$workdir/AVIC${model}NEX/BOOT/PJ${version}BOT.PRG"
mv newBootImage.img "PJ${version}BOT.IMG"
defaultheader="00060301010000000100000000000000504A313530424F5402100000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"
#get image size
# for mac
# SIZE="$(stat -f%z PJ${version}BOT.IMG)"
#for linux
SIZE="$(stat -c%s PJ${version}BOT.IMG)"
SWAPPEDHEXSIZE="${vSIZE:6:2}${vSIZE:4:2}${vSIZE:2:2}${vSIZE:0:2}00"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}BOT.IMG)"
#create new header
perl -e "print pack 'H*', 'A55A5AA5${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}${defaultheader}'" > PJ${version}BOT.HEADERNEW
cat PJ${version}BOT.HEADERNEW PJ${version}BOT.IMG > PJ${version}BOT.PRG
rm -rf PJ${version}BOT.HEADERNEW
rm -rf PJ${version}BOT.IMG
rm -rf boot.img
rm -rf bootimg.cfg
rm -rf initrd.img
rm -rf zImage
rm -rf newUnpack
#lets work on the ver file
defaultheaderver="A55A5AA5C00000000006030101000000010000002C000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF010000000100000042004F004F00540000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000050004A0031003500300042004F0054002E005000520047000000000000000000000000000000000000000000000000000000000000000000"
SIZE="$(stat -c%s PJ${version}BOT.PRG)"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}BOT.PRG)"
perl -e "print pack 'H*', '${defaultheaderver}${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}A55A5AA5'" > PJ${version}BOT.VERSTART
UNSWAPPEDHEXCRC="$(crc32 PJ${version}BOT.VERSTART)"
perl -e "print pack 'H*', '${SWAPPEDHEXCRC}'" > PJ${version}BOT.VERSTART1
cat PJ${version}BOT.VERSTART PJ${version}BOT.VERSTART1 > PJ${version}BOT.VER
rm -rf PJ${version}BOT.VERSTART
rm -rf PJ${version}BOT.VERSTART1
rm -rf ../PJ150BOT.VER
mv ./PJ150BOT.VER ../PJ150BOT.VER
I can't get my device working without an 8100 SDCard and it's just not proper to RMA the device. I'm really hoping an employee with access to the raw SD Image is reading this and can help. I can keep things anonymous.
I'm also exploring JTAG but I've really screwed with the firmware on my unit so JTAGing a broken firmware will only get us so far and won't allow me to restore my device.
If it comes to JTAG, does someone have an x1xx unit or SDCard I can use to pull a pristine 8gb image?
So sadly, I modified init.rc with a command that fails and now causes my unit to boot loop.  (put a simple touch logs.txt for each storage device, a bit stupidly so when it fails the system reboots)
However the above script works perfectly to start us in the direction of custom firmware. And if someone has knowledge of bsp and android we can add to the init.rc scripts to dump the sd password.
I am working on an idea I have to hopefully recover my unit. Hopefully will have news soon.
Before considering about password, we dont even have proper way to dump SD card with password.
fail0verflow used Novena with custom kernel to get over this problem.
I dont think anybody in this forum has Novena.
So as I mentioned previously, making Raspberry Pi to support CMD42 is necessary to dump SD card
(Not sure it will work or not though)
Agreed. My plan was to use Novena, but first we must get the password.
Also here is some modifications to AdamOutlers Mapping:
common name - associated ver file - location in update
boot.img -  BOT.VER - BOOT/BOT.PRG
bootloader  - BTL.VER - n/a
UNKNOWN - BT.VER  GPS/GPS.PRG
userdata - DAT.VER - USERDATA/DAT.PRG
UNKNOWN - DTV.VER - DTV/DTV.PRG
2nd recovery.img - ERY.VER - RECOVERYEASY/ERY.PRG (runs if the deck cannot read the sdcard and is loaded into some memory)
UNKNOWN - GPS.VER - GPS/GPS.PRG
UNKNOWN - OPN.VER - PG150OPN/OPN.PRG
system.img - PLT.VER - PLATFORM/PLT.PRG
recovery.img - REC.VER - RECOVERY/REC.PRG
UNKNOWN - WWR.VER - WWR/WWR.PRG
UNKNOWN - SNAPSHOT.VER SNAPSHOT/SNAPSHOT.PRG
HIBENDIR HIBENDIR  (Special partition)
Based on the fail0verflow blog the sd card for a 5000NEX partition should look like this:
Disk /dev/mmcblk1: 8069MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End     Size    Type      File system                          MY Findings:
 1      538MB   548MB   10.5MB  primary   android      boot A                  BOOT/BOT.PRG
 2      548MB   559MB   10.5MB  primary   android      boot B
 3      559MB   1830MB  1271MB  extended
 5      559MB   590MB   31.5MB  logical   android      recovery A              RECOVERY/REC.PRG
 6      590MB   622MB   31.5MB  logical   android      recovery B              RECOVERYEASY/ERY.PRG ?
 7      622MB   1159MB  537MB   logical   ext4         /system                 PLATFORM/PLT.PRG
 8      1159MB  1293MB  134MB   logical   ext4         /cache
 9      1293MB  1830MB  537MB   logical   ext4         /data                   USERDATA/DAT.PRG
 4      1830MB  7702MB  5872MB  primary   ext4         /extdata
Also, I have modified the code to now also open the USERDATA PRG and the EASYRECOVERY for editing.
https://code.casual-dev.com/5nP3
From what I can tell, the PRGS basically contain images that get flashed to the partitions of the SDCard. So if we can map those partitions to a PRG file we SHOULD be able to basically build sdcards from the update files. At least this is my theory based on what I can tell.
I can not tell what SNAPSHOT or OPN are. They do not appear to be ANDROID images and SNAPSHOT will not mount like a ext partition.
I think that HIBENDIR is the LineoWARP http://www.lineo.co.jp/modules/products/warp2.htmland it is possible the SNAPSHOT file goes with this.
Very good work. that's the entire android system, there. We just need a fool-proof way to recover devices.  If you can figure out how to deodex your SYSTEM.img (/system/framework and /system/app), and test it to verify your device boots up properly,  I can rewrite the code to remove the warning screen.
@AdamOutler here is an SDCard part on Pioneer's site that is supposed to the the 8100. http://parts.pioneerelectronics.com/part.asp?productNum=CXX7606
If we can get the sdcard password, I could then get image my sdcard (from an 8000 but should work since they can update each other) and hand off.
Did the SDCard from the 5000 not work?
I ordered this SDCard.  it's on back order.  I requested that it come without encryption/sdcard lock in the special requests field.   They obviously need to make new ones anyway, maybe they could just not lock the SDCard before sending it.
I'd hope I don't have to send my device out for JTAG.  I have something lined up, but it's expensive and I'm not earning money on this.
I thought SDCard was the flash on this device.   There is a second storage?
https://fail0verflow.com/media/img/avic/cpu-top-large.jpg
MX29LV640ETTI is 64Mbit NOR flash that contains U-Boot
Not sure if Pioneer going to lock it or not, but make sure to dump before you insert into 8100
I remember that reading post that NEX automatically locks SDCard with the password that stored inside flash.
So, make sure to try dump first, otherwise you would not be able to dump it anymore (unless you have password)
