bass_rock Posted August 5, 2015 Report Share Posted August 5, 2015 Using copy_script.sh, get the output of 'netcfg' before and after the usb device is connected. if that doesn't work, check "ifconfig eth0", "ifconfig usb0", and "ifconfig wlan0", then change the 0's to 1s So without anything attached the following script: #! /system/bin/sh out="/mnt/udisk/log.txt" echo "--ifconfig-- eth0" 2>&1 >>$out ifconfig eth0 2>&1 >>$out echo "--ifconfig-- eth1" >>$out ifconfig eth1 2>&1 >>$out echo "--ifconfig-- usb0">>$out ifconfig usb0 2>&1 >>$out echo "--ifconfig-- usb1" >>$out ifconfig usb1 2>&1 >>$out echo "--ifconfig-- wlan0" >>$out ifconfig wlan0 >>$out echo "--ifconfig-- wlan1" >>$out ifconfig wlan1 2>&1 >>$out echo "--id--">>$out netcfg 2>&1 >>$out Produces: --ifconfig-- eth0 --ifconfig-- eth1 --ifconfig-- usb0 --ifconfig-- usb1 --ifconfig-- wlan0 --ifconfig-- wlan1 --id-- lo UP 127.0.0.1/8 0x00000049 00:00:00:00:00:00 eth0 DOWN 0.0.0.0/0 0x00001002 1e:ed:19:27:1a:b3 tunl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 sit0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 ip6tnl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 What I find interesting is that a eth0 does seem to exist without anything connected. When I do connect a cheap wireless or ethernet adapter the output stays the same. Time to look at the board. If anyone sees something let me know. Quote Link to post Share on other sites
WhatIsWhatIsWhatIsWhat Posted August 5, 2015 Report Share Posted August 5, 2015 [deleted post] Quote Link to post Share on other sites
AdamOutler Posted August 5, 2015 Report Share Posted August 5, 2015 @AdamOutler what about iGo licenses? iGo in your "new" device is still working? Or licenses are invalid now? There is no maps now? As your firmware does not contain maps for iGo. How your EXTDATA partition is created without actual maps and data in firmware from pioneer? If iGo is working but without maps, is it possible to update or upload free maps via naviextras? "First gps fix time" is changed to "now" or still older time? Can we "reset" iGo inserting new SD to update maps (free 45-day period after first gps fix)? Can you now insert your old SD card into device, is it working or shows invalid password now? What, like this? Quote Link to post Share on other sites
Lucca Posted August 5, 2015 Report Share Posted August 5, 2015 Great news, I found my SD Card password and found possibility to change all BSP settings, there is dump from my NOR flash: This 16 digits is a serial number of your SD..,but not the pass.,the pass. must be 8 digits. Quote Link to post Share on other sites
AdamOutler Posted August 5, 2015 Report Share Posted August 5, 2015 Great news, I found my SD Card password and found possibility to change all BSP settings, there is dump from my NOR flash: This 16 digits is a serial number of your SD..,but not the pass.,the pass. must be 8 digits. Heh, they probably made the password a checksum of the serial. Quote Link to post Share on other sites
gotofbi Posted August 5, 2015 Report Share Posted August 5, 2015 Great news, I found my SD Card password and found possibility to change all BSP settings, there is dump from my NOR flash: A5 5A 5A A5 // ulong ulSignature; 00 00 00 00 // ulong ulbootmode; // 0 00 00 00 00 // ulong ullaunchmode; // 4 00 00 00 00 // ulong ultestsubmode; // 8 00 00 00 00 // ulong ulbootimageflag; // 12 00 00 00 00 // ulong ulrecoveryimageflag; // 16 00 00 00 00 // ulong uldebugswitch; // 20 00 00 00 00 // ulong ulusbotgswitch; // 24 00 00 00 00 // ulong ulmemchkflag; // 28 00 00 00 00 // ulong ulwarpboot; // 32 02 00 00 00 // ulong ulsubbootmode; // 36 06 00 00 00 // ulong ulupdateflag; // 40 01 00 00 00 // ulong ulupdatesubflag; // 44 XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX // password 00 00 00 00 // ulong uluiupdateflag; // 64 FF FF FF FF // ulong ulreserved1; FF FF FF FF // ulong ulreserved2; D5 72 B1 12 // ulong ulcrc32; Congratulation! May I ask how did you dump NOR? Did you use JTAG? Quote Link to post Share on other sites
fuzznec Posted August 6, 2015 Report Share Posted August 6, 2015 I follow this thread since the start and this is awesome ! But now i see that all message by whatisbypass are [deleted post] ?? What is happening ? Quote Link to post Share on other sites
joemamma1954 Posted August 6, 2015 Report Share Posted August 6, 2015 I follow this thread since the start and this is awesome ! But now i see that all message by whatisbypass are [deleted post] ?? What is happening ? Could be he deleted them himself, normally if deleted by moderator, it just will disappear. Quote Link to post Share on other sites
ils15 Posted August 6, 2015 Report Share Posted August 6, 2015 now here in brazil we are working in Igo NextGen... We will try to crack license and use new Here Maps In Brazil, last update is 2014.Q2 (Naviextras update) But more recently Nokia Maps updated to Here 2015.Q1, and then working very well on old IGO unitsIf anyone have this new license files, please, send me inboxthanks Quote Link to post Share on other sites
