Hello, Fellows!
Recently I bought a new car with a Pioneer avicF930bt system.
Unfortunately there was a password after doing a firmeware update for the radio. :/
So lukily Condi's HackMode v2.21 worked perfectly fine and i could remove the password!
So i thought... okay time for the removal using this uninstaller by gweny:
http://avic411.com/index.php?/topic/36854-undo-condis-hack-mode/page-2&do=findComment&comment=330314
But now i have the same problem as hlekinfr.
I have a loading screen but nothing else...
I cannot install Condi's HackMode v2.21 again or load the uninstaller ...
Strangely i can update the firmware...
Can someone help me?!!!!!!!
maybe it's a problem because I installed Condi's HackMode v2.21
but used an uninstaller for version 2.1 ?!!!
HELP!!!
and thanks a lot!
  • 1 month later...
Ok, instead of what hlekinfr suggested above I tried something else.
By searching the forum I found another post by hlekinfr uploading his
X9310BT user backup folder (http://avic411.com/index.php?/topic/80807-moderators-please-remove-condis-hackmode-v221/?hl=%2Bsuper+%2Btestmode&do=findComment&comment=331750).
By going to http://home.comcast.net/~cinful75/x9310bt/  I used the supertestmode to boot into maintenance.
I copied all the folders/datas from my avic-f930bt on the sd-card (I finally made a backup by this).
Then i compared prg0 und prg1 at the X9310BT user backup to point out what was different/missing
compared to my f930bt prg0 and prg1.
So prg0 and prg1 have to have basicly the same folders and datas so I coypied from prg0 to prg1 what was missing (if you have the same issues try to find out whats different with your avic, maybe you have to do it a little bit different) and deleted the old av.exe replacing it with the av.exe from X9310BT user backup.
After that I copied everything to my sd, booted into testmode, replaced the folders (don't forget to unmount the sd) and booted anew.
Finally I can use my avic before the trouble I had with gwenys hackremoval.
At this point I would like to recommend everyone who wants to delete/rewrite the password to use the supertesmode!!
It's all you need and it's less trouble!! ;)
  • 2 weeks later...
I've been trying to get the destructive HackMode v2.21 deleted from this site ever since I've been here.  There's a reason for that.
  • 3 months later...
  • 3 months later...
