Jump to content
AVIC411.com
If you just want to upgrade your firmware you do not need the testmode key, what do you want to do exactly?
I want to update the firmware. But when I do that, it fails immediately regardless of what firmware version I use. The OS reads the flash drive properly, detects the new version of the firmware, but then when I press Confirm to have it go through the update, it jumps immediately the "Update Failed!" screen. I've tried multiple USB drives and multiple versions of firmware. This is why I feel something is corrupt,because when I reset the device, and it reads the USB key to do a firmware update after the failure, it says Update Progress... "v 1.01 - > 1.01" which is clearly wrong. So basically something corrupt is preventing my unit from updating firmware so I wanted to restore/flash new recovery and boot partitions to potentially fix this issue with the testmode key.
Share this post
Link to post
Share on other sites
From what I understand, on your USB key if you put the firmware AND the testmode key, from the menu you will be able to flash separate partition as you will. For instance if you fucked up your "platform" partition (/system), from this menu you can reflash it individually.
So I tried what you mentioned...use the Write Programs Forcibly method on the testmode key with the USB drive containing the firmware items following these steps:
  1. Built the testmode key with the firmware I wanted on the same USB stick.
  2. Put it into USB1, powered on the unit.
  3. Selected Write Programs Forcibly, pressed HOME.
  4. Selected Write Bootloader, Pressed HOME.
  5. Selected the USB, saw the correct version information, Pressed HOME.
  6. Device reset, and when to Update Failed screen shown in pic.
  7. and now it's just stuck on this screen...and pressing Home to reset just brings it back to this. Removing the USB key makes it remain on the Device Mount screen until a timeout occurs. See pics.
    post-147073-0-05518600-1510284914_thumb.jpgpost-147073-0-09935500-1510284920_thumb.jpg
Pretty much stuck there for now. Can't seem to get it to boot into any other functionality.
Share this post
Link to post
I think testmode_a lets you boot in android and testmode_n in the NOR bootloader or something, I don't know if you can have a script there on your usb key or something to reflash from here? Some people here knows more than me.
Or I guess you can open your unit to take the SD card out and copy a raw image of your firmware on it.
Share this post
Link to post
To do that I'll have to unlock my SD card, which hasn't been done yet. I'm gonna see what the state of my SD card is this evening after work.
Share this post
Link to post
So I can't successfully get the Transcend 8GB SD card inside my 7000NEX to be recognized by my windows PC. I'm not entirely surprised given this thing is what, formatted for a Linux/Android OS? So I'm still trying to figure out how to go about confirming the state of my SD card and it's configuration. Any guidance or input would be helpful if anyone has insight how to successfully read the contents of the SD card from windows if it hasn't been unlocked using the methods described in this original thread.
Share this post
Link to post
Hi guys...
Every time I turn on my device, there is a long wait for the music to start playing.
I use an external 500gb hd with about 12.000 songs in FLAC.
I noticed that this is due to the creation of a database file of ID3 data.
I do not use the "TAG" interface in the search of files, but rather, "Files names".
So my doubt: is it possible to modify some files so that this indexing process does not occur ?
The database file can be found and copy to external device in DEVELOP DEBUG MENU -> DATABASE SAVE. In my case, the file is about 10mb.
Thanks.
Share this post
Link to post
We have finally cracked pioneer navigation software (iGO NextGen)
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
You can copy manually content and licenses through File Manager, using copy_script or by inserting internal sd card into your PC.
Don't forget to set proper filesystem rights to newly copied files.
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB)  FW 1.07/1.08
attachicon.gifx000_1.07_9.18.13.411863.rar
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB) FW 1.11/1.13/1.14/1.15 - iGO ver: 9.18.28.610126
attachicon.gifx000_1.11_9.18.28.610126.rar
 -  x100(5100-8100NEX F970BT/DAB/TV F70/77DAB)  FW 1.05/1.07/1.10 - iGO ver: 9.18.28.610130
attachicon.gifx100_1.05_9.18.28.610130.rar
 x200(AVIC-x200NEX/AVIC-Fx8x )  FW 1.00/1.02/1.07 - iGO ber: 9.18.28.624842
attachicon.gifx200_1.00_9.18.28.624842.rar
Use latest winrar5 http://www.rarlab.com/download.htm
Hi everyone!
Does anybody have mirrors to download the maps??? I want to upgrade my 7000NEX but the gpspower page hasn't validated my account (I've been waiting for 4 days). Any help is appreciated
Thank you
Share this post
Link to post
Hi everyone!
Thank you
 Can someone post that links again,  all links are broken,  Thank you
Can someone please post good links.
Share this post
Link to post
I dont have the first x000 but here are the other 3
   -N/A
    -http://www37.zippyshare.com/v/umaUmJrz/file.html
   -http://www37.zippyshare.com/v/rNSxly7G/file.html
   -http://www37.zippyshare.com/v/QX47zzdn/file.html
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
