Jump to content
The AVIC Development Mod
bsp avic development developer dev xda android auto android linux kernel boot
  • Please log in to reply
482 replies to this topic
#466 Magister
Magister
  • Members
  • 11 posts
Posted 05 January 2017 - 06:13 PM
I keep getting read-only filesystem warnings.  What I've noticed is that the content of build.prop on /system actually becomes 0 in size immediately after the operation, even though it says it's read-only.  What's going on here?
I pretty much piggybacked off the iGo lib fix that was just recently released in this thread.  I assume that one works fine.
I am having exactly the same problem on my 5200NEX, I changed the iGo lib script to change 2 files in /etc and I have the same behavior, it says read-only and 0 size:
/mnt/udisk/script.sh[13]: cat: <stdout>: Read-only file system
/mnt/udisk/script.sh[14]: can't create /system/etc/mediamanager.conf: Read-only file system
Unable to chmod /system/etc/sysd.conf: Read-only file system
Unable to chmod /system/etc/mediamanager.conf: Read-only file system
Any fix for this?
#467 Magister
Magister
  • Members
  • 11 posts
Posted 06 January 2017 - 05:53 PM
Any fix for this?
My conclusion:
we cannot change the filesystem with script on the 5200... even if I insert in the script, just before a "cat", this command:
mount -o remount,rw /system
I see in my output.txt:
mount: Read-only file system
my id is root, I checked:
uid=0(root) gid=0(root)
and here is the before first remount:
/dev/block/mmcblk0p7 /system ext4 ro,relatime,user_xattr,barrier=1,data=ordered 0 0
and after:
/dev/block/mmcblk0p7 /system ext4 rw,relatime,user_xattr,barrier=1,data=ordered 0 0
So something (kernel?) is preventing me from modifying the /system partition.
Anyone with a x200 can change files in lib or etc?!?
EDIT: by checking /system/lib I can see I have the new libigo, so the very first time I ran a script weeks ago, it worked, but now I guess the system detected the filesystem has been changed/corrupted and is blocking any more changes. I may try to inject a fsck in a script? or just reflash the PJ160PLT.PRG partition...
#468 Inspectifier Wrectifier
  • Members
  • 16 posts
Posted 06 January 2017 - 06:14 PM
My conclusion:
and after:
Yo dawg, what's da Android version?
I see barrier=1, dat might be preventing write, but if dat filesystem be power-on write protected, u be in fo' problems.
If I wuz u, I'd remove dat sdcard and 'tempt a manual decryption, den mount an write with a *nix box. After yous got write access, further testing will be required to determine if it's just temp write protect, boot write protect or perma write protect. Could be all three, yo!
#469 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 15 January 2017 - 09:34 PM
Ive been having problem with loading igo. Backed up nor and internal sd. Loaded Jenkins script to disable warp and take password off internal sd card. Restart. Pioneer logo is there for about 1 second. Black screen. Took internal sdcard out and flashed original copied off unit. Same thing. Is it possible to put original nor back on?
#470 WhatIsWhatIsWhatIsWhat
    Member
  • Members
  • 225 posts
Posted 15 January 2017 - 10:16 PM
You can restore BSP area using serial (UART) connection via yellow connector on back side of your unit.
Please join our Pioneer-related groupchat to get help. Sorry, I do not read or respond to private messages. Please contact me via groupchat.
#471 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 15 January 2017 - 10:30 PM
In other words I am screwed. Lol
#472 WhatIsWhatIsWhatIsWhat
    Member
  • Members
  • 225 posts
Posted 15 January 2017 - 10:33 PM
In other words you can restore your device in three minutes (including unit boot time).
#473 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 15 January 2017 - 10:48 PM
I am sorry in advance. But I need to buy a (UART) cable. Then somehow send the nor files I saved back onto the unit?
#474 WhatIsWhatIsWhatIsWhat
    Member
  • Members
  • 225 posts
Posted 15 January 2017 - 11:17 PM
You can buy 3.3 volt compatible USB-UART adapter ($2-$3 for Chinese clones from Aliexpress). Just connect three wires (GND, TX, RX) from adapter to your head unit and you will get access to bootloader console where you can change BSP settings to restore boot process.
#475 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 16 January 2017 - 12:05 AM
I am specifically looking for one that is a cable correct ? a lot are a board with pins and a USB soldered on. How would one know which are tx,rx,ground pin layout.
#476 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 16 January 2017 - 12:26 AM
Deleted
#477 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 16 January 2017 - 01:51 AM
Thanks WhatIsWhatIsWhatIsWhat
Updated
Pin layout
16 - tx
17 - rx
26 - ground
Just need to get a USB to UART cable
#478 Svoiss
Svoiss
  • Members
  • 12 posts
Posted 16 January 2017 - 12:14 PM
What's the recommended program to use?
#479 asd255
asd255
    Member
  • Members
  • 140 posts
  • LocationRussia
Posted 17 January 2017 - 07:34 AM
PuTTY
#480 lunatics
lunatics
  • Members
  • 7 posts
Posted 18 January 2017 - 03:28 PM
Hey guys I am looking for some quick advice/help and hope it's not too much to ask.
I upgraded/updated my maps almost a year ago and got them up to date with Q3 2015 I believe at that time. I see Q3 2016 is out now and I would really like to upgrade to this. The problem is I kind of forgot exactly what I did to do it before and lost the flash drive I had used for it and I feel like I had found another guide that went a little more indepth that I am having trouble finding again now.
Esentially I would like to upgrade from where I am, to 2016 newest maps. I want to backup my unit before I do this. I have a folder on my desktop called "igo backup" and in it I have "copy_script.sh" "script.sh" "sdcardcwwversion.txt" "sdcarddataversion.txt" and "testmode_a.key" Is this all I need? I thought there was a script to actually move the files necesary.
If this is the right files I need for my flash drive, does the testmode_a.key get me into the mode where I can manually copy and paste things? Can I get in here and copy my entire igo folder to create a backup of everything I have now incase something goes wrong? The only thing is I remember having an issue where I would get error messages trying to copy everything to my device manually and I thought I had used a script to copy the whole igo folder and am at a loss now what to do and do not want to brick my device.
Also tagged with one or more of these keywords: bsp, avic, development, developer, dev, xda, android auto, android, linux, kernel boot
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
