OrangeFool Posted May 1, 2019 Report Share Posted May 1, 2019 On 2/12/2017 at 9:37 PM, fixed said: I got ADB debug over USB working perfectly first go, from what I'm reading others are having issues? * Enable debug menu * Change USB mode to 'device', headunit reboots * Enable debug menu * Enable 'ADB on usb' option * lsusb on a Linux machine connected to it using a standard USB male<>male cable shows a device as a Nexus 7 in debug mode * 'adb shell' gives you a shell Does this enable on both USB ports? Quote Link to post Share on other sites
Hoangnova Posted June 16, 2020 Report Share Posted June 16, 2020 Anyone have the new debug menu password? the DEVELOPDBG ON no longer works. Quote Link to post Share on other sites
baniak_ko Posted August 29, 2020 Report Share Posted August 29, 2020 Hi Guys, On newer firmware, where DEVELOPDBG ON password doesn't work anymore, there is a way to skip the password prompt. At least it works on my F970BT. The buttons sequence is based on the original one shown at first post in this theme but slightly modified. Sequence I use is: 3-1-3-1 (all short presses), then press button 2 for longer period than previous buttons, but not long enough for the password prompt to appear. After that press button 2 again, but this time for a longer period. Tested on avic F970BT, firmware AVIC-Fx7x_EU5_FW_Ver_111. Quote Link to post Share on other sites
Mav2u Posted August 30, 2020 Report Share Posted August 30, 2020 Doesn’t seem to work for avic5000nex. Quote Link to post Share on other sites
swechsler Posted October 21, 2020 Report Share Posted October 21, 2020 On 8/30/2020 at 2:17 PM, Mav2u said: Doesn’t seem to work for avic5000nex. Same for SPH-DA120. Quote Link to post Share on other sites
asd255 Posted October 22, 2020 Report Share Posted October 22, 2020 starting with firmware 1.15+ this method no longer works Quote Link to post Share on other sites
Danypolo5 Posted March 18, 2021 Report Share Posted March 18, 2021 hi, I have a pioneer avh-z9200dab, the thing I don't like is that every time I turn the key the stereo turns on, regardless if at the time of turning off the car it was on or off do you know a way to fix this? i thought i find something about debugging..but i can't find passwords Quote Link to post Share on other sites
bonee Posted March 18, 2021 Report Share Posted March 18, 2021 2 hours ago, Danypolo5 said: hi, I have a pioneer avh-z9200dab, the thing I don't like is that every time I turn the key the stereo turns on, regardless if at the time of turning off the car it was on or off do you know a way to fix this? i thought i find something about debugging..but i can't find passwords What???? Quote Link to post Share on other sites
kyler_9406 Posted May 25 Report Share Posted May 25 Can I back up the internal SD card in this mode? The test key is no longer working for my avh-x8850. If possible, how can I proceed? Quote Link to post Share on other sites
Join the conversation
