Pirrama Posted March 2, 2016 Report Share Posted March 2, 2016 RonS, Currently I'm on version 5. I was aware about full formatting of SD card and 16KB cluster size allocation. If I insert SD card into the HU when it is already running it plays some strange music file. And for sure, I have AVIC-F840BT. Maybe you can advise how to install a third party software on my unit? I would gladly use something like "Navigon" or "CityGuide". Thanks a lot for trying to help me. I really appreciate it. Quote Link to post Share on other sites
BlakeStone Posted March 2, 2016 Report Share Posted March 2, 2016 Pirrama, More specutlation here, if your F840BT is wired directly to the battery instead of the ignition, it may be that you unit never gets turned off so it doesn't actually boot the sd card when you turn on the ignition. If you find that is true, put the sd card in your unit and remove one of the battery cables for 30 seconds or so and then reconnect and see if your unit boots. Quote Link to post Share on other sites
Pirrama Posted March 3, 2016 Report Share Posted March 3, 2016 Pirrama, More specutlation here, if your F840BT is wired directly to the battery instead of the ignition, it may be that you unit never gets turned off so it doesn't actually boot the sd card when you turn on the ignition. If you find that is true, put the sd card in your unit and remove one of the battery cables for 30 seconds or so and then reconnect and see if your unit boots. Thanks for the suggestion. I will give it a try. Should I remove the password first? Quote Link to post Share on other sites
BlakeStone Posted March 3, 2016 Report Share Posted March 3, 2016 If you know the password, then there's no need to remove it but some people just delete it anyway. Quote Link to post Share on other sites
Pirrama Posted March 4, 2016 Report Share Posted March 4, 2016 Just a thought. Is there any way that my password prevents unit from the update? Quote Link to post Share on other sites
BlakeStone Posted March 4, 2016 Report Share Posted March 4, 2016 Doubtful, but it's not hard to re-make it if you delete it for testing. Quote Link to post Share on other sites
jaog2003 Posted March 7, 2016 Report Share Posted March 7, 2016 Hi! What´s files I need for update bluetooth in F930BT?? Thank. Quote Link to post Share on other sites
Travolta Posted March 21, 2016 Report Share Posted March 21, 2016 Hi! What´s files I need for update bluetooth in F930BT?? Thank. Only the folder with Bluetooth. The device will find it if you copy the folder to root and go to update. Regards Quote Link to post Share on other sites
joeda Posted March 27, 2016 Report Share Posted March 27, 2016 Hi folks, late to the party! does anyone have a working link for map update for my f9210, only working link i can find has a non working zip file, I already have password. thanx. Quote Link to post Share on other sites
jaog2003 Posted March 27, 2016 Report Share Posted March 27, 2016 Only the folder with Bluetooth. The device will find it if you copy the folder to root and go to update. Regards Sorry, Where´s the folder with bluetooth? Thank. Quote Link to post Share on other sites
Martin78 Posted March 30, 2016 Report Share Posted March 30, 2016 Hi folks, late to the party! does anyone have a working link for map update for my f9210, only working link i can find has a non working zip file, I already have password. thanx. Try link from Blakestones post #656 and password from #679. Worked like a charm on my F9220BT . And a big thanks to all who have contributed in this post and forum, you guys have helped med a lot! Quote Link to post Share on other sites
john77 Posted April 2, 2016 Report Share Posted April 2, 2016 Files deletet why delete this when we paid for it Quote Link to post Share on other sites
john77 Posted April 2, 2016 Report Share Posted April 2, 2016 Like I said, you don't have to do any thing like copying files into folders... just put the folders and file from the zip onto your sd card as they are. I don't know anything about the TTS files as I didn't use them, so you'll have to read the forums to figure that out. lets hope flomsen dont delete this hole page in thisforum is there a way to save all these 700- 800 posts very usefull info here Quote Link to post Share on other sites
john77 Posted April 2, 2016 Report Share Posted April 2, 2016 Here is the VERINFO.DAT file hi thanx u saved me to but in my alldata.htm file is also zero bytes, is this right Quote Link to post Share on other sites
RonS Posted April 2, 2016 Report Share Posted April 2, 2016 hi thanx u saved me to but in my alldata.htm file is also zero bytes, is this right It isn't zero length on mine (2015 US/CAN). Not sure if it matters. Just a text file in html format. Here's mine for the Z140: <html><head><title> Navigation Data </title></head><body bgcolor="#ffffff" text="#000000"><pre> [Navigation All Data Record] Product : T1000-23348 DataType : All Data BulidTime : 2015/04/20 11:29:22 Release Version : 06.000000 </pre> </body> </html> For the Z120 the Product tag and BuildTime are different: <html><head><title> Navigation Data </title></head><body bgcolor="#ffffff" text="#000000"><pre> [Navigation All Data Record] Product : T1000-23346 DataType : All Data BulidTime : 2015/04/16 17:45:29 Release Version : 06.000000 </pre> </body> </html> Don't know what your's is. Probably only the Product tag is important. Quote Link to post Share on other sites
