goodoane Posted December 5, 2015 Report Share Posted December 5, 2015 Please can any one post the Romanian TTS voice coming with the last update(2015), is about 125Kb. I will like to compare with the voice that I already have that work with the same engine nua_v5. I was able to extract some how the last update(2015) but I am confuse because the voice that I extracted are in a strange format not a zip file. Lock like thisĀ EU090TTS.RUMĀ and I am not sure If this file is encrypted or It need to be like this. If any one can help or give me some hints... please do. Thank you. Quote Link to post Share on other sites
goodoane Posted December 6, 2015 Report Share Posted December 6, 2015 After more research I find that the structure of the voice is correct. Any one know a way to parse this type of files to get the resources?... Quote Link to post Share on other sites
hacim27 Posted December 6, 2015 Report Share Posted December 6, 2015 I updated (Eu 2015 map) my f9220bt unit. It works fine. there are lots of quest. about 9220 update: pls use this link (http://bit.ly/1Xp3qws) to download sd card files. unrar pass: 42E6FF89843D8BA94C4B2FFBA6624 After formatting (fat 32) the 4+gb sd card (i dont know whether it is compulsary or not) copy the downloaded sd card files to your sd card. download the f9220 compatible cardinfo.cif modded file from this link http://s000.tinyupload.com/index.php?file_id=96464814939960980540 copy it to sd card root and replace cardinfo.cif file. that is all. PLUG YOUR Ć¢ā¬ā¹Ć¢ā¬ā¹SD CARD TO YOUR F9220 UNIT THĆ¢ā¬ā¹AN INST.PROCESS WILL TAKE 25 MIN. ready to Ć¢ā¬ā¹answer your further question. Quote Link to post Share on other sites
JhonnyB Posted December 6, 2015 Report Share Posted December 6, 2015 Need this update for the AVIC-F70DAB Quote Link to post Share on other sites
TomĆĀ© Posted December 6, 2015 Report Share Posted December 6, 2015 Good evening,will be that this updating and compatible with Pioneer Avic F50BT?Thanks. Quote Link to post Share on other sites
Marek320 Posted December 7, 2015 Report Share Posted December 7, 2015 Question about upgrade my Avic-F940BTĀ (Eu 2015 map) Ā download files on sd card: FIRMWARE UPDATE CARDINFO.cif Ā modified on 13-4-2015 10:06 (do I have to change this file or leave it en start upgrade ?) Ā I'ts the first time i do this, and want be sure that I am doing the right thing in one step. Ā Thanks Quote Link to post Share on other sites
frisk Posted December 11, 2015 Report Share Posted December 11, 2015 on 940bt, you can upgrade without modifying anything... Quote Link to post Share on other sites
Marek320 Posted December 12, 2015 Report Share Posted December 12, 2015 on 940bt, you can upgrade without modifying anything... Updated from Platform version: 4.000 to 6.000 in 25 min. Thanks Quote Link to post Share on other sites
simbad88 Posted December 19, 2015 Report Share Posted December 19, 2015 Thanks a lot pmc2 Ā Ā It works flawlessly on my F920BT Ā Ā Enclosed cardinfo.cif zipped CARDINFO.zip VERINFO.DAT Quote Link to post Share on other sites
wizzle Posted December 21, 2015 Report Share Posted December 21, 2015 I have a avic F10bt that is upgraded to software version F20BT 2013.I got the files and the cardinfo.cif andĀ VERINFO for older models. Is that enough to install the update. Or do I need the dutch TTS files?Just did the update and it worked for me.....! In dutch... Quote Link to post Share on other sites
iumba Posted December 21, 2015 Report Share Posted December 21, 2015 I have avic F20bt, I already updated with 2013 maps downloaded here, with this files it doesn't boot from sd Ā What files are good for me? Quote Link to post Share on other sites
wizzle Posted December 21, 2015 Report Share Posted December 21, 2015 I have avic F20bt, I already updated with 2013 maps downloaded here, with this files it doesn't boot from sd Ā What files are good for me? Just pickup the files a few page back, place the cardinfo in the root and verinfo in the update. Quote Link to post Share on other sites
iumba Posted December 21, 2015 Report Share Posted December 21, 2015 It works! Thanks a lot! Quote Link to post Share on other sites
padrefloryn Posted December 23, 2015 Report Share Posted December 23, 2015 It works on my F9310. Thanks! But i have this problem: On the screen it appears a message Ć¢ā¬Å¾Restarting the sistem because of a tuner errorĆ¢ā¬,then Ć¢ā¬Å¾OKĆ¢ā¬. I press ok but appears again. What should i do? (at least not to see this message anymore). HEEELP PLEASE ! Quote Link to post Share on other sites
JhonnyB Posted December 23, 2015 Report Share Posted December 23, 2015 Is this possible on the AVIC-F70DAB? Ā Thank you. Quote Link to post Share on other sites
Join the conversation
