CELL Posted September 7, 2015 Report Share Posted September 7, 2015 nvm, its working. Changed only on prg1 because i have user/prg.flg Quote Link to post Share on other sites
burago Posted September 14, 2015 Report Share Posted September 14, 2015 Hello, i tried the modification without having the file "user/prg.flg". Unfortunatelly, it doesn't work. Is there an other way to fix correctly the Navi.exe file? or do you know how i can generate this famous "user/prg.flg"? thank you in advance. I have update my F930BT with 2015 Maps. Quote Link to post Share on other sites
sea Posted September 15, 2015 Report Share Posted September 15, 2015 HÄ°Ä° Quote Link to post Share on other sites
Corvus Posted September 15, 2015 Report Share Posted September 15, 2015 Hello, i tried the modification without having the file "user/prg.flg". Unfortunatelly, it doesn't work. Is there an other way to fix correctly the Navi.exe file? or do you know how i can generate this famous "user/prg.flg"? thank you in advance. I have update my F930BT with 2015 Maps. if USER\PRG.FLG file exists you have to patch USER\PRG1\APL\Navi.exe or else you have to patch USER\PRG0\APL\Navi.exe Hex edit navi.exe 6.0 @ offset BEC64 0500000A -> 0000A0E1 Quote Link to post Share on other sites
burago Posted September 17, 2015 Report Share Posted September 17, 2015 thank you corvus, i did it but "USER\PRG.FLG" does not exist. Quote Link to post Share on other sites
mdpapth Posted September 23, 2015 Report Share Posted September 23, 2015 Hi, I can confirm that the old navi.exe (provided as a rar file in this forum) works on a patched F930BT with Map 2015 update.- It removes the nagging warning screen when going to navigation mode. Thanks to this forum. I like. What I now would appreciate is an update of the speedcams (internally, not on SD card). Thanks Quote Link to post Share on other sites
youngsyp Posted September 23, 2015 Report Share Posted September 23, 2015 Hi chaps, Can you point me in the right direction of the 2013 nag bypass thread? I've found another thread with a link but the link is dead and no amount of massaging the URL seems to coax a live thread. Thanks in advance, Paul Quote Link to post Share on other sites
Corvus Posted September 23, 2015 Report Share Posted September 23, 2015 Hi, I can confirm that the old navi.exe (provided as a rar file in this forum) works on a patched F930BT with Map 2015 update.- It removes the nagging warning screen when going to navigation mode. I downloaded and tried that old navi.exe, and it worked for me to,but when I checked the file, I found out that it has to be navi.exe file from ver 4.01 or something. I diddent want to have that so I checked the 6.0 file. After som fiddling I found the offset to change. Hex edit navi.exe 6.0 @ offset BEC64 0500000A -> 0000A0E1 Quote Link to post Share on other sites
Corvus Posted September 24, 2015 Report Share Posted September 24, 2015 This is really easy to do yourself. Open your navi.exe 6.0 file in HxD hex editor (tiny program) Browse down to offset bec64. Change 0500000A -> 0000A0E1. Save file on sd. Put testmode.key on sd and fire up your device. if USER\PRG.FLG file exists you have to swop USER\PRG1\APL\Navi.exe or else you have to swop USER\PRG0\APL\Navi.exe Remember to delete the navi.exe on device before you start copy it from sd because testmode.key dossent suport overwrite. The you copy navi.exe from sd to device. No more nag, and you the latest ver off navi.exe. Quote Link to post Share on other sites
xmansss Posted September 27, 2015 Report Share Posted September 27, 2015 It worked perfect for my F840BT. I had to change USER\PRG1\APL\Navi.exe in my case. No mor nag. Thanks! Quote Link to post Share on other sites
erdem84 Posted November 7, 2015 Report Share Posted November 7, 2015 Worked like a charm on F940BT. Thank you very much Quote Link to post Share on other sites
giblets46 Posted December 31, 2015 Report Share Posted December 31, 2015 HI, bit confused, can't seem to be able to locate BEC64 in navi.exe in PRG1 or PRG0, am I missing something ( F-30bt) with 2015 maps. cheers Quote Link to post Share on other sites
Corvus Posted January 4, 2016 Report Share Posted January 4, 2016 HI, bit confused, can't seem to be able to locate BEC64 in navi.exe in PRG1 or PRG0, am I missing something ( F-30bt) with 2015 maps. cheers To find the rigth offset if your not familiar with hex can be confusing.Locate offset 000BEC60. On that row in column 4 you find offset 000BEC64. Column 4 starts with 05, column 5 with 00 and so on. Or use the search, goto function. Punch in 000bec64... Quote Link to post Share on other sites
giblets46 Posted January 5, 2016 Report Share Posted January 5, 2016 To find the rigth offset if your not familiar with hex can be confusing. Locate offset 000BEC60. On that row in column 4 you find offset 000BEC64. Column 4 starts with 05, column 5 with 00 and so on. Or use the search, goto function. Punch in 000bec64... Perfect,. thanks! What a noob! the code was different in PRG0, but looked right in PRG1, so will look to copy that, and hope it works! Edit: Works perfectly, many thanks again! Quote Link to post Share on other sites
Pirrama Posted January 28, 2016 Report Share Posted January 28, 2016 Hi All! Just a quick one. Is it possible to replace original "Navi.exe" with edited one and then run the 2015 update? Or AVIC will detect the change? I just thought that it would be more convenient to replace exe file on SD card before the update, rather than struggle with copy/paste after the update? Thanks. Best Regards, Alex. Quote Link to post Share on other sites
