randomwalk101 Posted October 25, 2015 Report Share Posted October 25, 2015 The attached CARDINFO will work for 130BT/140BT by prompting "Update: Yes/No"....However, when you go past that, it'll say "Incorrect SD card" ... CARDINFO.zip Quote Link to post Share on other sites
Alexei Navalny Posted October 25, 2015 Report Share Posted October 25, 2015 The attached CARDINFO will work for 130BT/140BT by prompting "Update: Yes/No"....However, when you go past that, it'll say "Incorrect SD card" ... Then why post it? What Cardinfo file was this based on? It begins with "#PIONEER3" instead of our "PIONEERQ". My theory is that some of those characters after PIONEER" relate to the UPDATE image. Try making the mod with the US 2015 Cardinfo file. Just replace the Z110bt label "X07UNC" with "X71UC0" (Z130bt) and "X30UNC" with "X14UCO" (Z140bh). If that works, the X series guys can replace "X27UNC" with "X72UNC" (x930bt) and maybe randomly replace some 6 characters with" X15UC0" (X940BT). I think it is important to keep the file size to 300 bytes. Quote Link to post Share on other sites
Alexei Navalny Posted October 25, 2015 Report Share Posted October 25, 2015 I have my ipod wired and I cannot control it through the head unit after applying the 2015 update. I'll try falling back to the 2012 bluetooth firmware and see if that fixes my bt audio issue, but this will not fix my issue of not being able to control the ipod through the head unit. I'll report back if the 2012 bt firmware fixes my issue. Thanks for all the help. Did you set Settings/AV System Settings/App Connection to Wired? Quote Link to post Share on other sites
vicdawg Posted October 25, 2015 Report Share Posted October 25, 2015 Did you set Settings/AV System Settings/App Connection to Wired? Yes, this setting has always been set to Wired. Thanks for the help though. Downgrading to the 3.24 bt firmware didn't fix my issue either. I guess I'll just have to stick with the 2013 map update. Quote Link to post Share on other sites
jfwalsh99 Posted October 25, 2015 Report Share Posted October 25, 2015 The attached CARDINFO will work for 130BT/140BT by prompting "Update: Yes/No"....However, when you go past that, it'll say "Incorrect SD card" ..ThT This CARDINFO.CIF file is from the 2012 (v4.0) update. Even though it will work for the Z110BT, Z120BT, X920BT, and Z130BT as shown by the HEX dump, it won't work with the 2015 update because it is searching for version 4.0 (2012) update, therefore the "Incorrect SD card" error. Quote Link to post Share on other sites
randomwalk101 Posted October 25, 2015 Report Share Posted October 25, 2015 Okay, I took the CARDINFO from this thread (2015 update) and modded it to support Z130BT and Z140BT. This should hopefully work now. It's crazy raining here I can't get to the truck outside to test. Give it a try. Make sure you back up /USER directory first. CARDINFO.rar Quote Link to post Share on other sites
jfwalsh99 Posted October 25, 2015 Report Share Posted October 25, 2015 Okay, I took the CARDINFO from this thread (2015 update) and modded it to support Z130BT and Z140BT. This should hopefully work now. It's crazy raining here I can't get to the truck outside to test. Give it a try. Make sure you back up /USER directory first. Just tried your modded CARDINFO file on a Z140BH. Still displays "incorrect SD card" message. I verified the SD card I am using is good by using the 2013 (v5.0) update. I attached a HEX dump image of the 2013 V5.0 Z110BT/Z120BT and Z140BH. As you can see, every value, except #PIONEER, is different. I can only assume that this would be the case with the 2015 V6.0 CARDINFO files. I was hoping to get the EU CARDINFO file to see if it might be easier to modify since the Z140BH and F40BT units are identical. Quote Link to post Share on other sites
randomwalk101 Posted October 26, 2015 Report Share Posted October 26, 2015 Hmm...try this one. I just downloaded from the 2015 EU thread...that someone posted it. Not sure if it'd work but it's for "Here the modded CARD.INFO file, 2015 edition for F20/ F920 / F9210 / F9220" I'm hoping we can mod it for 130/140? CARDINFO_2015.rar Quote Link to post Share on other sites
Alexei Navalny Posted October 27, 2015 Report Share Posted October 27, 2015 Just to keep it simple for now, I'd recommend replacing "X14EU0" (F40BT) with "X14UC0" (Z140BT) and "X71EUR" (F30BT) with "X71UNC" (Z130BT). That replaces the EU F series units with US/CN versions of that hardware. So hopefully if any of those other mysterious characters are important, they will match. If this works with Z130 & Z140, then the X series (X930 & X940) can be added. Quote Link to post Share on other sites
FreeTime Posted October 27, 2015 Report Share Posted October 27, 2015 I have been following this thread for a few days. Can someone tell me which card info would b the one for a x920bt that has had the CNSD-210FM map upgrade. thx for your time guys Quote Link to post Share on other sites
Alexei Navalny Posted October 27, 2015 Report Share Posted October 27, 2015 I have been following this thread for a few days. Can someone tell me which card info would b the one for a x920bt that has had the CNSD-210FM map upgrade. thx for your time guys The one from the original post - use the link in post #12. That should work as-is. Quote Link to post Share on other sites
Tomé Posted October 27, 2015 Report Share Posted October 27, 2015 Good afternoon,I have the Pioneer Avic f50bt with the Europe 2013 maps, it is possible to update maps of 2015?My thanks. Quote Link to post Share on other sites
Alexei Navalny Posted October 27, 2015 Report Share Posted October 27, 2015 Good afternoon, I have the Pioneer Avic f50bt with the Europe 2013 maps, it is possible to update maps of 2015? My thanks. I don't think so. This is the US/CAN map upgrade. Check on the F-Series forum. They should know. Quote Link to post Share on other sites
pionara Posted October 27, 2015 Report Share Posted October 27, 2015 cardinfo.cif is just signalling unit that there is an update on the SD card. I dont think it has versioned information. I do know that there are some special fields at char position 16 and 17. I think they are normally ascii "00" and can be 01, etc but I dont recall exactly what those are used for. Regarding the rest of the cardinfo, starting at about the 20th char, and every group of 6 chars after that, there could be the model codes that were discussed before. This goes on through much of the rest of the file, and then there may be some other section towards the end of the file, again not sure if thats used or what its used for. So you can replace or add your own model code in there. I think that if your model code is listed in cardinfo.cif and the unit reboots, then cardinfo is finished. So the problem here is not with cardinfo. The verinfo has a major version and i think an update type (normal vs urgent). I think this is also set correctly to do an update. The ALLDATA.VER has a manifest of all the files in the update, including size and crc32. I think this is used by update to verify the files are correct. I'm suspecting that something else isn't right in the case of "Incorrect SD card" - perhaps there is an os-level "platform" update which is only for certain hardware model. Quote Link to post Share on other sites
pionara Posted October 27, 2015 Report Share Posted October 27, 2015 to see the structure of the cardinfo.cif, you can run this command (linux/mac) on cardinfo and see where the model codes are placed. I think they can be anywhere in the middle as long as they are on these 6 letter boundaries. Seems like there is alot of obfuscation there. sed -e 's/#Pionee//' -e 's/....../&\n/g' CARDINFO.cif Quote Link to post Share on other sites
