Jump to content
2015 Avic Z120 map update
  • Please log in to reply
251 replies to this topic
#226 milespjking
milespjking
  • Members
  • 15 posts
Posted 22 November 2016 - 04:22 PM
be careful if you want to use this update with cd-IV202NAVI for lightning cable connectivity
don't update your unit with this map before you read chapter. 6 of this link
http://www.navigatio...T1000-23348.pdf
if your firmware is 4.0 then update it to 4.6
if your firmware is 5.0 then update it to 5.1
or you will never be able to get the menu "ipod settings" in your avic for fully functional iphone 5 or higher connection
i updated my unit to firmware 6.0 without thinking enough
Sadly I can not find any possible solution to use my iphone 5s in my car
now i ended up spending extra $70 for nothing
don't make the same mistake i made
#227 RonS
RonS
    Established Member
  • Moderators
  • 1424 posts
  • LocationBelleair Beach, Florida
Posted 22 November 2016 - 04:48 PM
Did you try using the PRG.FLG file to toggle back to the previous version stored in the alternate /USER/PRG directory tree? If it works you should be able to install the appropriate iPod support patch. Then re-install v 6.0
#228 milespjking
milespjking
  • Members
  • 15 posts
Posted 22 November 2016 - 05:13 PM
 Thank you for the head up
 and I have sincere appreciation for your devotion to this forum
 the method you talking is this?
http://avic411.com/i...first/?p=337737
#229 RonS
RonS
    Established Member
  • Moderators
  • 1424 posts
Posted 22 November 2016 - 05:22 PM
Yes. You should be able to revert to the previous version (the active PRG directory) by creating or deleting /USER/PRG.FLG. Also, it usually is a good idea to make a backup of /USER on to SD before making any changes. However you can always create a new PRG.FLG since it is just an empty file.
#230 milespjking
milespjking
  • Members
  • 15 posts
Posted 22 November 2016 - 05:29 PM
I haven't tried it yet
I will try it later in the day
and get back to the forum
#231 milespjking
milespjking
  • Members
  • 15 posts
Posted 23 November 2016 - 06:56 AM
I tried as RonS proposed but nothing worked so far
I updated my unit to 6.0
then I figured there is no way I could install the "ipod settings" on the firmware
when i tried it i was stuck in the "program foreced write" step.
my ucom version was 8.12 and ucom version i got from the 5.1 firmware just showing me --.------ rather than 8.05
I tried formating my two different sd cards mutiple times but still.
so i re install firmware 5.0 again.
then I tried 5,1 firmware and it was looking good
showing me copying some files as you updating firmware.
until the "program forced write" step
still it was same as i stated above.
after that when I lookeed in to my service information
it says firmware version is 5.0
           application version is 5.1
but no "ipod settings"
then I tried to roll back my firmware with RonS' idea
it did roll back my firmware to  firmware version is 5.0
                                                application version is 5.0
and I tried to install 5.1 into my unit
then this again  'stuck in the "program foreced write" step.
my ucom version was 8.12 and ucom version i got from the 5.1 firmware showing me --.------ rather than 8.05'
now I am trying to reinstall firmware 4.0 with fingercrossed
#232 milespjking
milespjking
  • Members
  • 15 posts
Posted 24 November 2016 - 12:04 PM
*update*
  I am using my jailbroken iphone 4 with my avic flawlessly
  I want to mirror my phone to the navigation
  and it works perfectly
  only one problem I've got here is iphone 4 is too laggy
  so I decided to use my iphone 5s and bought cd-iv202navi.
  unfortunately, I haven't found any way to work with it.
  However, today, I exprienced some strange behavior of my avic
 even though all the hassels i went through here http://avic411.com/i...pdate/?p=342370
 except the initial try of getting it working, I haven't connected iv202navi to the gps.
 I just checked if "ipod settings" would show up in the av setting menu.
I am using my avic with firmware 5.0 now
i connected iv202navi today and checked if it would work with a iphone5s
when I connected my iphone5s to the gps
"ipod" in the av source menu did not show up (which would show up on the left side of screen when you connect ipod to the avic)
then I update firmware to 5.1
still everything looking promising until the "program foreced write" step
after this incompleted update, still no ipod setting option in the av setting menu
BUT, in the av source menu (which is left side of screen), there was ipod menu.
I didn't even connect my phone to my avic
so I connected my jailbroken iphone5s to the unit
and my iphone5s screen mirrored into the avic, also was getting charged.
then I tried my iphone7+, it mirrored into the unit, also getting charged.
but no sound.
I decided to reset the unit by disconnecting the battery. (I solved some iphone connectivity problem before with this  method)
after the reset, ipod menu on the av source was gone.
I rolled back firmware to ver. 5.0 and updated to ver 5.1 a couple of times
but haven't come back.
I felt like i almost got it...
and I wonder if there is any possible way to keep the ipod menu in the av source even though iphone(ipod) is not connected to the unit?
#233 treker
treker
    Member
  • Members
  • 23 posts
Posted 25 November 2016 - 10:51 PM
Are you answering to my previous thread where i question rons for the navi patch?
A bit lost here :-)
Rons, when i did the update in my f940bt i did not change the cif file with your text in it. Should i have done it and update the 2015 map? This nag screzn is driving me crazy!
Thx for your help.
#234 RonS
RonS
    Established Member
  • Moderators
  • 1424 posts
Posted 26 November 2016 - 12:04 AM
I Rons,
i tried to find the offset on my Navi.exe file (F940BT) freshly updated with 2015 files, but this offset doesn' exist.
Any idea on pointing me how to remove the nag message?
in fact will write a bigger post as i got several issues on this unit as
1) i cannot enter the seting (greied) = brake green cable is grounded and the mute wire relocation doesn't work
2) I do not know where to copy my speedcam file in this damned unit !
Anyway on thing at a time.
Thanks a lot for your help.
If your file doesn't look like this it is a different file. I don't know if the F series uses the same program since there's no speedcam on the US.
#235 treker
treker
    Member
  • Members
  • 23 posts
Posted 26 November 2016 - 04:48 PM
thx for the answer Rons. you and Corvus wrote so much in these forums i didn't notice it was in front of my eyes !! :-)
I managed to patch my navi.exe for the nag screen of the F940BT and it works perfectly. :-)
Next 2 issues are where to insert my speedcams in the unit and also how to patch av.exe or navi.exe to get in safemode as my mute wire move to ground it with brake doesn't work and i still have Settings and other greied !!
For speedcams it seems that it is possible but noone can tell the exact folders where to put the speedcam.txt or .spud file (APL2??..)
#236 AuralArch
AuralArch
  • Members
  • 12 posts
Posted 02 December 2016 - 05:05 PM
I would like to express my sincere gratitude & heartfelt thanks to those who made this possible!!!  Particularly to kellinaradway for so generously sharing a copy of the update (although those files are no longer available nor used).  Massive thanks to RonS for tirelessly & graciously not only seeking out and posting links to solutions for virtually EVERY issue raised in this thread (AMAZING!!!) but also for continuing to repost answers/solutions (and/or links to them) for those who could not be bothered to read through the entire forum (which is certainly time consuming).  RonS is also the one who posted the still working links to the files which make this possible!  Also big thanks to MPTonyT for posting patched files...
#237 gpriore
gpriore
  • Members
  • 5 posts
  • LocationArizona
Posted 03 December 2016 - 06:38 AM
Ok so a BIG,BIG,BIG thanks to everyone that put all the hard work an time into this for us.
I have updated my frimware from 2.003 to 6.000 an to the 2015 USA CANADA MAP on my Avic Z120BT. I can not confirm about the other units but for the Z120 it was a piece of cake to do. I am by no means savvy at stuff like this so if I can do it anyone can. It is very straight forward and easy to do. If you read over this whole thread you will get all the answers you need.  An again a big thanks to everyone. I am very GRATEFUL TO YOU ALL!!!!!
So this is what I did for my Avic  Z120BT.
1. Downloaded this, click the blue link here for newer units    z130bt, z140bh, x930bt, x940bt - newer units
2. Once you have finished the download extract the files if need so. I didn't have to as Im on a Mac. You may have to extract the files if you are on a PC not sure about that.
3.Then open up the 2015 USA CANADA MAP UPDATE folder you downloaded. Find the CardInfo.CIF file then open the file with a text editor. Delete all the text and replace it with this info below. Copy from the # to the G in the text below.
#PioneerQPRX2MP00IUYJSO2NFRJA6QYICEG003IC1TD9OA3KWJTKXX9C3SCQX30UNCVY6O2C7W7QW14BK0OJDGF1K5X07UNCP79T4YGYNGVDX27UNCTNEPNWPBS1H4INT15XKYQ6XBLHEWPEWXN7342Q1WW8HWKXNLRWELALK6KIJU0PO17P3BF1UJXB8RHUYU9IL91RRBYIK15QVAEHTFQECMSSHF21XXJRTYY6U4XOMA7SPEUP21BCGQHT9EYQ4RV3WSUEC1JNSPIIMD61GDEYIKWC9EUCJKX8JICMVCG
4.  Then Copy  the UPDATE, FIRMWARE folders and the edited CardInfo.CIF  to the root of a freshly formatted FAT32 SD card larger then 4GB.
5. Then insert it into your unit an then hit ok to update. This will take about 25 minutes to do an you must leave the vehicle running to update.
6. After your uint boots back up an you finish the units setup go into the bluetooth setting an then hit update firmware. This will take about 10 to 15 minutes to finish.
DONT FORGET TO THANK THE OTHER USERS FOR THIER TIME IN MAKING THIS HAPPEN.
I have read this entire thread very carefully. I would like to thank all the great people that participated and offered their invaluable feedback.
I have the AVIC-Z120BT with the 2013 TeleAtlas Maps and the 5.0 firmware. I am exorbitantly happy with it. I strictly use the GPS and my iPod Classic 500GB with it, and 'nothing' else whatsoever. I have just one simple question, and would be immensely grateful to whoever would respond. I sampled the new AVIC-8200NEX at an authorized dealer who had it on full display. Since I knew in advance that the new systems and updates converted from TeleAtlas Maps to HERE Maps, I was curious to experience the actual difference. First of all, the primary reason I love the 2013 TeleAtlas Maps so much, is because, the graphics of the maps are so richly detailed and beautiful. And when I drive around in downtown, it gets ten times better. The numerous amounts of 3D buildings are HUGE and insanely detailed in such a gorgeous manner. When I sampled the HERE Maps in the new 8200NEX, I was devastated to see that the exotic richness in graphics were completely stripped bare, and 100% of all the detailed beautiful 3D buildings in downtown were completely eliminated!!! I was thinking...."What kind of FOOL would actually eliminate all this beautiful eye-candy!!!" It was a complete deal-breaker for me. But the only positive thing I witnessed about it {which was actually a MASSIVE improvement beyond belief} was, you can actually manually enter cross-streets of your choice as a form of direct destination!!! I was absolutely amazed by this, because, this feature is completely non-existent in the TeleAtlas Maps. So, there is both a huge positive and negative simultaneously.
My question is: Does this 2015 Map Update allow the AVIC-Z120BT to look and operate 'exactly' as I witnessed it on the new AVIC-8200NEX? And are there any other notable improvements that would make it similar to the AVIC-8200NEX?
#238 pdp76
pdp76
  • Members
  • 2 posts
Posted 06 December 2016 - 12:16 AM
I just updated to the newest firmware 6.0 and 2015 maps on my Z140BH.  Everything seems fine so far.  All the customization I've made (LED color, wallpaper, saved POIs, etc...) were retained through the update process as well.  So thanks to everyone who helped get this update out!
Quick question though, are there any release notes for Firmware 6.0?  I'm curious to know what exactly changed.  I don't even see firmware 6.0 on pioneer's website.
#239 RonS
RonS
    Established Member
  • Moderators
  • 1424 posts
Posted 06 December 2016 - 12:44 AM
On Navigation.com    Pioneer T1000-23348 addendum
#240 wascapsfan
wascapsfan
    Member
  • Members
  • 44 posts
  • LocationAtlanta
Posted 30 December 2016 - 11:42 PM
It might actually be an incompatible SD so you could get another 4 to 8 GB one very cheap and try that. Larger capacity or new fast ones seem to be problematic. It also could be a problem with the files. Are you using a Mac? The file extraction program might not be working right.
If you just want to abort the update altogether, you'll need to get into  TestMode and delete \USER\SYSTEM\Download\StartKnd.log.
Then remove your TestMode SD (or USB stick), and it should restart into regular mode on next power up.
I tried this and it still says version 6.0
PIONEER AVIC X930BT
ROCKFORD FOSGATE P500-2 X 2
ROCKFORD FOSGATE P400-2
KENWOOD PS200T
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
