knuhrme916 Posted January 26, 2016 Report Share Posted January 26, 2016 need some help, had my 8000 for awhile now and was working ok, except for blue tooth issues, did the update, and that fixed most of the issues, then went to use my navi the other day and it sits with wheel spinning when you click on the ok symbol I see screen go blank then igo loading comes up then it goes back to the av screen. tried several resets and pulled power, but nothing comes back. called pioneer and of course they want 80 to look at it to see what happened to it.. I think it was just too much of a coincidence that caused it to lose the maps after the update. Anybody have a possible solution for this? I would rather not be without my radio for 2 weeks... also noticed it dropped Pandora from the av options. Any suggestions would help.. Thanks. Quote Link to post Share on other sites
onebyside Posted January 26, 2016 Report Share Posted January 26, 2016 I never had any problems with my 8000 and the past 2 updates, or Map updates, or Bluetooth updates. Factory Reset the unit and see what happens. You could have a bad GPS ant...who knows the ant wiring if fragile enough if its been pinched. Quote Link to post Share on other sites
knuhrme916 Posted January 27, 2016 Report Share Posted January 27, 2016 i have reset it and also used reset button and pulled harness and let it sit for 10 mins... it restarts but the first time I try to goto nav it just shows igo loading, and then back to the main screen. Quote Link to post Share on other sites
huddy Posted January 27, 2016 Report Share Posted January 27, 2016 does it show the street names on the bottom when you are driving around in an AV setting? Have you tried starting Nav after driving the car a bit vs fresh off of boot up? Might be the AVICSYNC app on your phone causing problems? Delete the app and see if makes a difference. Quote Link to post Share on other sites
Lucca Posted January 29, 2016 Report Share Posted January 29, 2016 AvicSync have been updated! - Android - 9.18.28.624772 (Jan 14 2016) -iOS - 1.2.627081 (9.18.27.627081) (Jan 25 2016) Quote Link to post Share on other sites
sengvin Posted February 2, 2016 Report Share Posted February 2, 2016 Finally got my radio back from Pioneer back on Friday 01/29 after more than 5 weeks ! Wow New update is in 1.11 and this was also last time I have updated my unit because it is simply not worth the 5 weeks of waiting and $250 charge( Which I didn't pay this time because luckily my unit was still under warranty) What a hell ride ! Quote Link to post Share on other sites
Brndncatan Posted February 9, 2016 Report Share Posted February 9, 2016 i have reset it and also used reset button and pulled harness and let it sit for 10 mins... it restarts but the first time I try to goto nav it just shows igo loading, and then back to the main screen. I started a thread on this aswell, same problem that you're describing. Let me know if you find any solutions! Quote Link to post Share on other sites
erlee013 Posted February 9, 2016 Report Share Posted February 9, 2016 Does this update also update the maps? Because I was gonna update the maps from my usb stick after the firmware update and it says update package invalid...so anyone have any info on this? And I got my phone to connect with avicsync but it keeps saying looking for signal on my phone Quote Link to post Share on other sites
soccerdad1 Posted February 12, 2016 Report Share Posted February 12, 2016 Sorry for double posting but figured this thread was still getting action and my post is being viewed with no feedback. I have a AVIC-5100. I want to update to use AVICSYNC but an not sure of some things. I only have the software brake bypass. Will this work or do I have to ground a wire or ??? I don't want to brick this thing. I don't have a warranty on it. Thanks! Quote Link to post Share on other sites
Multitask Posted February 13, 2016 Report Share Posted February 13, 2016 Sorry for double posting but figured this thread was still getting action and my post is being viewed with no feedback. I have a AVIC-5100. I want to update to use AVICSYNC but an not sure of some things. I only have the software brake bypass. Will this work or do I have to ground a wire or ??? I don't want to brick this thing. I don't have a warranty on it. Thanks! I looked at Pioneers site, doesn't look like it is supported.... If you found a site that talks about a 'hack' for it to do that, then you risk it.... Not sure what you mean or if there is actually a question there about the break bypass.... Quote Link to post Share on other sites
huddy Posted February 13, 2016 Report Share Posted February 13, 2016 Sorry for double posting but figured this thread was still getting action and my post is being viewed with no feedback. I have a AVIC-5100. I want to update to use AVICSYNC but an not sure of some things. I only have the software brake bypass. Will this work or do I have to ground a wire or ??? I don't want to brick this thing. I don't have a warranty on it. Thanks! Does your unit flash the "parking wire not grounded" warning? If you read the bypass sticky thread on this forum, I believe you do have to have the parking wire grounded. The whole point of the software bypass is to override that grounding. So I would recommend getting your unit properly grounded prior to doing the update. Quote Link to post Share on other sites
soccerdad1 Posted February 13, 2016 Report Share Posted February 13, 2016 OK, I feel stupid. I thought this was for the 5100 as well. I now see that I just need the 1.05 firmware. Thanks for the replies. Quote Link to post Share on other sites
7knex Posted February 14, 2016 Report Share Posted February 14, 2016 Crash like thi? https://www.dropbox.com/s/yu112hpcbvpkuql/Video%2029-11-15%2C%2017%2019%2045.mov?dl=0 The only solution that i founded is put CarPlay under restriction in the phone. What do you mean "under restriction"? Carplay isn't causing the problem for me. Only when I have Avicsync AND Carplay at the same time. Carplay by itself doesn't cause the audio problems. Quote Link to post Share on other sites
7knex Posted February 14, 2016 Report Share Posted February 14, 2016 Also, I notice a little blue car icon with curved arrows in the lower right corner, which I had not noticed before (perhaps it was there before, but I just had not noticed) - pressing the icon did little more than turn it to blue, and I didn't notice anything else happening. Perhaps somebody can enlighten me as to what it is. Before the update, and following update of the iPhone to iOS 9.1/9.2, I began having problems with the sound, both on the iPhone and CarPlay. Sometimes, I could not get any music to play, and my ringtones would go haywire - basically, when the phone rang, it produced a loud, annoying, and continuous "BRAAAAAAAAAKK" sound. The only thing that I could do was turn the phone off and then back on. Everything would then be fine - until the next time. I have the feeling that this malady is related to CarPlay, but don't know. Item 1, I think that may have to do with AvicSync, but that's just a guess. Item 2, I had that problem. I uninstalled AvicSync and my phone has been fine since. I'd like to get AvicSync back on and working without hosing my iPhone, but until that happens, I'm ok without AS. Quote Link to post Share on other sites
7knex Posted February 14, 2016 Report Share Posted February 14, 2016 Has anyone managed to get the Avicsync app to pair with their NEX headunit after the update process? I simply can't get my iPhone 5S to associate with Avicsync via Bluetooth or USB. On the head unit, turn off carplay mode under settings - usb or something like that. When I had carplay enabled on the headunit, it would go to carplay mode before the head unit had a chance to ask me if I wanted to associate the phone for avicsync. Quote Link to post Share on other sites
