donmontalvo Posted January 17, 2016 Report Share Posted January 17, 2016 Just swapped out my 5000 and replaced it with a 6100. Absolutely 1:1 swap, no wiring work necessary. Or so I thought. Anyone know where this wire might be, I'm not an installer, so a pic might help. 2014 Honda CR-V AVIC-6100NEX. TIA, Don Quote Link to post Share on other sites
asd255 Posted January 17, 2016 Report Share Posted January 17, 2016 I have the same problem Quote Link to post Share on other sites
dvboy Posted January 18, 2016 Report Share Posted January 18, 2016 I had the same message after getting my unit installed,no idea what it means?? Quote Link to post Share on other sites
Lucca Posted January 18, 2016 Report Share Posted January 18, 2016 Just swapped out my 5000 and replaced it with a 6100. Absolutely 1:1 swap, no wiring work necessary. Read carefuly... Quote Link to post Share on other sites
huddy Posted January 18, 2016 Report Share Posted January 18, 2016 Also it will effect the ASL (Automatic Sound Levelizer) feature, which uses the VSS wire to determine whether or not to adjust the sound up or down depending on how fast the car is going. VSS wire connection also helps keep the Nav accurate when GPS signal is lost (ie. Tunnels, cities with lots of tall buildings, etc) and also gives slightly more accurate turn notifications. Otherwise, using the simple hybrid mode is fine for most day-to-day navigation needs. Quote Link to post Share on other sites
donmontalvo Posted January 19, 2016 Author Report Share Posted January 19, 2016 Interesting, I'll see if I can find a professional installer in the Los Angeles area who can look at this. Quote Link to post Share on other sites
Ken45 Posted January 9, 2022 Report Share Posted January 9, 2022 https://youtu.be/5FMimfxShJY. Shows you a simpler way of fixing the issue Quote Link to post Share on other sites
