mcfebras Posted January 17, 2017 Report Share Posted January 17, 2017 I tried to make a nextgen version for F900BT again. Maybe you can test it. Follow there instructions. Download link below. I have changed some files and now it is for European devices F900BT. Test it and let me know. I only made it for Dutch. So TTS files and voices are only for Dutch and English. I am not responsible when you brick your unit. https://1fichier.com/?0at95r5oim Installation Instructions 1) Back up your unit! Copy the entire "My Flash Disk" onto a SD card and keep it in a safe place. 2) Ensure you are running Windows CE version 5.0 or above. You can check this by booting into testmode, going to the control panel and tapping on system. It will tell you your CE version there. 3) Download the file. Extract, copy to a SD card. 4) Delete "My Flash Disk" on your unit from testmode. 5) Copy "My Flash Disk" from your SD card to your unit. 7) You have to copy maps/ POI etc to the folder in iGO/ Content. Do NOT copy them in Primo3/ Content 6) Reboot. Your unit will auto reboot once more to initiallize AVICnet. If GPS cannot be found, change port in sys.txt to GPS port of your device. And go to \My Flash Disk\User\UserData\iGo\SAVE folder and delete the SAVE folder. Hello~. I have done everything you said but iGo won't open. When I press to open it, the screen turns black and apperas "Please wait. Loading" Then it goes back to the main menu. If I press to open it again it repeats the process and never opens the iGO Nextgen. What is the problem? Thanks in advance. Quote Link to post Share on other sites
brunowillis Posted July 31, 2017 Report Share Posted July 31, 2017 Hi, Is there a new working version? If yes can somebody please share the flashdisk with avicnet and working Igo Primo 2.4 and Igo Primo NextGen? Would be awesome. Quote Link to post Share on other sites
seth_space Posted September 21, 2017 Report Share Posted September 21, 2017 Support that.. and can someone tell me if there is a version for a F930BT ? Thanks.. Quote Link to post Share on other sites
weresgyufa Posted January 5, 2020 Author Report Share Posted January 5, 2020 Hi there. There is another version, i have made a try and it is running too, I only have issues with TTS or TTS PRO, they are still not working, TMC I thing not but I can't test it fully. Quote Link to post Share on other sites
Join the conversation
