racemandk Posted June 1, 2016 Author Report Share Posted June 1, 2016 Hi take this link decompress put the speedcam who you are sure to use + next testmode folder https://drive.google.com/file/d/0B4MAukIOceEXTmU3Ql8tclJhb0U/view?usp=sharing put the sd card on your avic turn on your device click on total commander open storage card and on your flash disk open ( apl2 after open igo after open content and open speedcam folder copy your files inside ) turn off , retire the sd card and restart and select in menu alert alert on hi i tryed this link but it only contains teks file?? Quote Link to post Share on other sites
racemandk Posted June 1, 2016 Author Report Share Posted June 1, 2016 im now copying all the other files so hope it works, bluetooth was succesfull, sorry my late reply i was in holliday:-) and thanks soooooooo much again quizmo Quote Link to post Share on other sites
wk75 Posted September 4, 2016 Report Share Posted September 4, 2016 Hi. Guizmo I have got Pioneer avic F9110BT navigation with map ver. 02.000600 and firmware 3.02100 (language polish). Could You tell me, which one file i should use, to upgrade it? THX. Quote Link to post Share on other sites
ingerericson Posted September 5, 2016 Report Share Posted September 5, 2016 Hi copy my flash disk and put the folder testmode next on a sd card and when you put the sd card on your device turn on your avic and when you are on windows screen 1) click on total commander at the left side open storage card and at the right side open your flash disk 2) copy all files of my flash disk on your flash disk 3) after you do this take the 2 winces files inside the folder nammed PLT on the 320200 version 4) put them alone on a sd card and do this put the sd card on your avic turn on your device press in the same times 3 touch ( menu,map,eject ) + with stylet press the reset when the screen was black retire the stylet of reset the screen come blue retire your fingers of 3 touch avic try a code do this with joystick up ,up , down , touch menu , left , right and press the center of your joystick to confirm select first line press the center of your joystick and after with the joystick select upgrade wince ( no format) press the center of your joystick to confirm the avic read winces when you have a message 100% writing restart your device turn off your device and retire the sd card and restart for the map and poi copy all files on a sd card and open total commander and copy in your flash disk ( open apl2 and igo and content) copy the map and other things you use https://drive.google.com/file/d/0B4MAukIOceEXY1FYUEtOeUdtN1k/view?usp=sharing https://drive.google.com/file/d/0B4MAukIOceEXS0l5MC1IQ28tLVE/view?usp=sharing for lang and voices https://drive.google.com/file/d/0B4MAukIOceEXa25pd3NNVWFBMEE/view?usp=sharing https://drive.google.com/file/d/0B4MAukIOceEXT2NoZmJWSEhoN2M/view?usp=sharing I used your first link and the only map I see is hungery??? am I doing something wrong or is it missing ? Quote Link to post Share on other sites
Join the conversation
