QB89Dragon Posted May 10, 2016 Report Share Posted May 10, 2016 Hey all. I've got a 2012 Canadian STI with the X9310BT installed from factory. I've previously updated to the 2013 maps with no issues. I followed the guide here to update my firmware last month, and the maps work great, however there's numerous glitches with the audio / entertainment. To list a few: iPod is detected but won't start playing music Aux-in no longer works Playback from SD card takes several power cycles of the device before it functions Bluetooth audio and handsfree calling no longer works (both before and after BT firmware update) If there's any further info I can give you guys with troubleshooting, just ask. I'm driving from Edmonton to Idaho Falls tomorrow and it'll suck without some tunes! Thanks! Quote Link to post Share on other sites
BlakeStone Posted May 10, 2016 Report Share Posted May 10, 2016 Remove all power for 30 seconds. This is a known fix that works after doing an update and getting your kind of issues. The unit needs a full reboot after an update. Disconnect one of the battery cables so there is no power getting to your unit. This should fix everything. Quote Link to post Share on other sites
QB89Dragon Posted May 11, 2016 Author Report Share Posted May 11, 2016 Remove all power for 30 seconds. This is a known fix that works after doing an update and getting your kind of issues. The unit needs a full reboot after an update. Disconnect one of the battery cables so there is no power getting to your unit. This should fix everything. Awesome, thank you for the tip! Unit works great now. Quote Link to post Share on other sites
