7200NEX, iGO Not Working, Help, SD Card
Hi,
I have the 7200NEX and when you select MAPS it says iGO loading and then it closes. Everything else with the unit is working well.
How can I fix this issue?
Where is the SD card located?
Are there any step by step instructions?
Thank you for the help! :)
- Matthew
[symptom]
When pressing the "NAVI" icon on the navigation model, the Map is not displayed.
"Loading iGO..." appears and then return to the previous screen.
 [Cause]
The license file on the SD card is damaged
[Remedy] Only applicable for the above symptom!
update/rewrite the SOC ucom with latest firmware
No need to replace the SD card.
Installing the latest firmware which is published on the consumer website.
  • 3 months later...
[symptom]
 [Cause]
soc ucom?
