Sjarrel Posted April 12, 2017 Report Share Posted April 12, 2017 Hello, Today i recieved a Here map update Europe 2016, now i want to read and copy the files to share but im not able to see whats on the sd card. I guess it's not windows based so i try'd several linux tools to see whats on the sd, and again no luck. Is there anybody who can tell me what to do with it so we can share it??? Plz let me Know ASAP!! Greetings and hope to here it soon Quote Link to post Share on other sites
Alexei Navalny Posted April 12, 2017 Report Share Posted April 12, 2017 Hello, Today i recieved a Here map update Europe 2016, now i want to read and copy the files to share but im not able to see whats on the sd card. I guess it's not windows based so i try'd several linux tools to see whats on the sd, and again no luck. Is there anybody who can tell me what to do with it so we can share it??? Plz let me Know ASAP!! Greetings and hope to here it soon There's a thread where they cracked the 2016 Here update for the z150/x950 (US/Can) version. I suspect the same method will work for you too. Read through the entire thread since there were a few mis-steps early on. Thanks for contributing. Quote Link to post Share on other sites
Sjarrel Posted April 12, 2017 Author Report Share Posted April 12, 2017 Here's a thread where they cracked the 2016 Here update for the z150/x950 (US/Can) version. I suspect the same method will work for you too. Read through the entire thread since there were a few mis-steps early on. Thanks for contributing. Hi Ron, i looked at the topic but i cant see the solution about to read the sd card. Tommorow im gonna try to install the update and hope to know more by tommorow evening Quote Link to post Share on other sites
Alexei Navalny Posted April 12, 2017 Report Share Posted April 12, 2017 Hi Ron, i looked at the topic but i cant see the solution about to read the sd card. Tommorow im gonna try to install the update and hope to know more by tommorow evening Yah, it's not very clear what solved the problem. The talk about the USB cable makes me wonder if they used an SD to USB adapter. Since I don't have a x50 unit, I didn't get deeply involved in that effort. Maybe you could PM nezfotnemom to get details. Quote Link to post Share on other sites
markich07 Posted April 13, 2017 Report Share Posted April 13, 2017 Thats awesome what are you trying to do...i follow this post definitely.. Quote Link to post Share on other sites
Sjarrel Posted April 13, 2017 Author Report Share Posted April 13, 2017 I want to read the sd card in my computer, it's not visible due to the format of the sd card. i want to find out wich program i need to see the content on the sd card! Today i installed it on AVIC-F950BT and it works like a charm. Hope that someone will find out what to do or give me a tip Quote Link to post Share on other sites
Alexei Navalny Posted April 13, 2017 Report Share Posted April 13, 2017 I want to read the sd card in my computer, it's not visible due to the format of the sd card. i want to find out wich program i need to see the content on the sd card! Today i installed it on AVIC-F950BT and it works like a charm. Hope that someone will find out what to do or give me a tip As I said above, those z150/US-Can guys were using USB. Maybe they were using the headunit (in testmode) to copy all the files from the SD to a FAT32 USB device? Then they could copy/archive the files at will. Quote Link to post Share on other sites
Sjarrel Posted April 13, 2017 Author Report Share Posted April 13, 2017 That could be the solution indeed, I didn't understand what you were saying about the USB earlier. Thnx Quote Link to post Share on other sites
nezfotnemom Posted April 19, 2017 Report Share Posted April 19, 2017 It was a bitch.. since there is encryption it made it that hard.. lol.. I literally booted the test mode, put in the card, then copied the directories over 1 by 1 in chunks.. took like 2 hours Quote Link to post Share on other sites
Tdpp Posted March 21, 2018 Report Share Posted March 21, 2018 Hola, tiene alguien la actualización del pioneer avic-F950bt? gracias Quote Link to post Share on other sites
