Iggie Posted April 30, 2017 Report Share Posted April 30, 2017 I just got a unit with bricked software. I loaded testmode onto SD and realized that someone tried using HackMode... However, it loads now after repairing av.exe and some other files but many options are disabled (like basic configuration, bluetooth... etc) because it seems that some files and folders are still missing. I need a backup from the similar unit so I would be grateful If someone can help. Thank you very much in advance and I hope I am not asking a lot since this is my very first post. Cheers! nand.txt Quote Link to post Share on other sites
Alexei Navalny Posted April 30, 2017 Report Share Posted April 30, 2017 Some settings will not work if the parking brake isn't detected. So either set it or bypass. Quote Link to post Share on other sites
Iggie Posted April 30, 2017 Author Report Share Posted April 30, 2017 Some settings will not work if the parking brake isn't detected. So either set it or bypass. I did that. On most devices it is a light green wire connected to GND. Quote Link to post Share on other sites
Alexei Navalny Posted April 30, 2017 Report Share Posted April 30, 2017 I did that. On most devices it is a light green wire connected to GND. I don't have an F series, so IDK if that bypass method works. On my Z series, you need to add a wire to the harness and ground both (green and new). On the Z, you can tell whether the PB is detected by going to Settings / Navi Settings / Connection Status. Your's probably does too. Quote Link to post Share on other sites
Iggie Posted April 30, 2017 Author Report Share Posted April 30, 2017 Yes, I shorted black and light green wires together, because cannot enter any advanced menu. Still I think that problem is in the USER folder but cannot find any backup as I did with my previous unit (F90BT). Unfortunately the folder structure is not same with F920. Quote Link to post Share on other sites
Alexei Navalny Posted April 30, 2017 Report Share Posted April 30, 2017 Yes, I shorted black and light green wires together, because cannot enter any advanced menu. Still I think that problem is in the USER folder but cannot find any backup as I did with my previous unit (F90BT). Unfortunately the folder structure is not same with F920. Have you tried installing the map upgrade (2015)? http://avic411.com/index.php?/topic/82391-avic-f10f20f920f9210f9220bt-evrope-maps-update/ Quote Link to post Share on other sites
Iggie Posted April 30, 2017 Author Report Share Posted April 30, 2017 Have you tried installing the map upgrade (2015)? http://avic411.com/index.php?/topic/82391-avic-f10f20f920f9210f9220bt-evrope-maps-update/ Yes I did and it is the same no matter on firmware or map version. SOLVED by replacing RAM. Now the unit does not restart by itself and all options are available. Thank you, RonS. Quote Link to post Share on other sites
nosb Posted November 6, 2018 Report Share Posted November 6, 2018 Hello I have the same unit Bricked to : reset loop Can you help me with make backup of your unit ? Quote Link to post Share on other sites
