yann Posted May 14, 2017 Report Share Posted May 14, 2017 Hi guys, I just bought a used f950bt, it worked very well but I pressed the security key in the parameters which has the effect of blocking some of the functions. As I did not know how to remove this mode, I unplugged the battery to reset. But when I switched on I can not type the code because the keyboard is disconnected. Yes i am idiot I installed the testmode but I do not know how to activate the keyboard. who can help me Yann Quote Link to post Share on other sites
Alexei Navalny Posted May 14, 2017 Report Share Posted May 14, 2017 Hi guys, I just bought a used f950bt, it worked very well but I pressed the security key in the parameters which has the effect of blocking some of the functions. As I did not know how to remove this mode, I unplugged the battery to reset. But when I switched on I can not type the code because the keyboard is disconnected. Yes i am idiot I installed the testmode but I do not know how to activate the keyboard. who can help me Yann Try setting the parking brake. Quote Link to post Share on other sites
bhasurup Posted November 8, 2017 Report Share Posted November 8, 2017 Hi guys, I just bought a used f950bt, it worked very well but I pressed the security key in the parameters which has the effect of blocking some of the functions. As I did not know how to remove this mode, I unplugged the battery to reset. But when I switched on I can not type the code because the keyboard is disconnected. Yes i am idiot I installed the testmode but I do not know how to activate the keyboard. who can help me Yann Can you let me know where you got testmod for f950bt? Quote Link to post Share on other sites
