NEW Firmware for: x000 - ver:1.15/1.18, x100 - ver:1.10, x200 - ver:1.06/1.07
atm you just have to have alot of patience :) btw i think you can downgrade the unit to an older version, then the patch/crack will work.
You sir are a genius - I'd assumed it couldnt be rolled back (Pioneer website says you cannot) - downloaded the 1.14 from the link on this forum, fired it up on the headunit - got a warning it was older than current did I wish to continue, then simply said yes and installed 1.14 over the top! Had to do the bluetooth rollback too, but now working fine - testmode works perfectly, and I've patched out the annoying nav warning 'OK' screen  :-P
  • Replies 30
platform x200:
AVH-X8800BT - 1.06 download
AVIC-F980BT - European (EU5) model - 1.07 download
AVIC-F980BT - Russian (UR) model - 1.07 download
Is the 8200NEX different than the AVH-X800BT?  I'm just confused as to why this is firmware version 1.06 but the Pioneer web site only has version 1.04 for the x200 series.  Thanks for any help educating me.
NEW Firmware for AVIC\AVH x000\x100\x200 platforms
update: june 2017
Test Mode does not work with old keys
platform x000:
AVH-X8600BT - 1.15 download
AVIC-Fx6x EU5 верÑÐ¸Ñ - 1.15 - download
AVIC-Fx6x UW5 верÑÐ¸Ñ - 1.15 - download
SPH-DA120 EU - 1.18 download
platform x100:
AVH-X8700BT - 1.10 - download
AVIC-F970BT - European (EU) Model - 1.10 download
AVIC-F970BT - Russian (UR) Model - 1.10 download
platform x200:
New keys available for the new firmware
asd255 was so kind to share some Golden apples & eggs with us. The content he provided contained some different versions of testkeys. The one we need (i thnk) is the tech one, so this is the one im sharing.
Use the goldenapple.tst key with your preffered patch
pass: avic411
Hopefully admins/asd255 dont mind if i share this file,...otherwise please edit this post
GOLDENAPPLE.zip
  • 4 weeks later...
pass: avic411
Can you please provide instructions on how to bypass OK Screen at startup using this Golden Egg? Did a quick search, can't find anything.
only works on the x000 platform (incl. 5000-8000NEX/F960BT/F60DAB, AVIC-F960BT / AVH-X8600BT / SPH-DA120). Not on the x100!
pass: avic411
  • Download file
  • Unpack downloaded file(s) into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
  • Your device will reboot into testmode.
  • Select Write program forcedly => Copy Script, script will patch your system and reboot.
  • Remove USB stick after script finishes.
​NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE!
remove_pl_and_smartphone_OK_screen_x000.zip
  • 3 weeks later...
  • 2 weeks later...
