jim2154 Posted March 17, 2019 Report Share Posted March 17, 2019 On 2/23/2019 at 4:18 PM, DaveVdz said: I have an easy fix that worked just fine, leave you contact and I gladly share. whats the fix this isn't working for my new 4000 Adal2154@gmail.com Quote Link to post Share on other sites
jim2154 Posted March 17, 2019 Report Share Posted March 17, 2019 On 2/23/2019 at 4:18 PM, DaveVdz said: I have an easy fix that worked just fine, leave you contact and I gladly share. it didn't work on mine whats the easy fix? adal2154@gmail.com Quote Link to post Share on other sites
bonee Posted March 17, 2019 Report Share Posted March 17, 2019 Easy fix send to pioneer. Just put in the work. It's worth it. Quote Link to post Share on other sites
ecbrow1 Posted April 2, 2019 Report Share Posted April 2, 2019 How/where do I get this goldenkey from? I don't think this works with the newest FW upgrade Quote Link to post Share on other sites
swt180 Posted April 7, 2019 Report Share Posted April 7, 2019 So i think im in the same situation needing this GoldenKey. Had an SD card go bad, downloaded and installed the required image and got the unit working again, then did a firmware update to 1.11 (before doing this i set a password (second attempt and didnt have a password so got locked out straight away). Worked fine for a little, then updated the BT on the unit and surprise surprise it asked for the password, but the password isnt the one i initially set and the password hint is blank. Any help would be appreciated Quote Link to post Share on other sites
Alexei Navalny Posted April 7, 2019 Report Share Posted April 7, 2019 9 hours ago, swt180 said: Any help would be appreciated You might try this. Service Password Method (worked on AVH4400NEX) Link to Service Password Method Quote Link to post Share on other sites
TheBum Posted April 16, 2019 Report Share Posted April 16, 2019 On 4/7/2019 at 7:34 AM, RonS said: You might try this. Service Password Method (worked on AVH4400NEX) Link to Service Password Method THANK YOU!!! This worked on my AVH-W4400NEX. Quote Link to post Share on other sites
camCC Posted November 21, 2019 Report Share Posted November 21, 2019 i am having same issue on a vehicle that i just purchased. i replaced the battery and now a password pops up and i have no clue what it is. please help!!!! Quote Link to post Share on other sites
AUSCE Posted December 30, 2019 Report Share Posted December 30, 2019 For me it did not work, we formatted 2GB USB in FAT32, unzipped the RAR file and restarted the drive, nothing happened. Unfortunately the numerical part of the keyboard as well as the bar are locked, I tried to do it via USB and it does not work, because the code is numerical, I do not know why this time when disconnecting the battery stopped working, previously it had already happened without problems, a couple of months ago, however in this occasion the last line was blocked, numbers, space and the go key, do not respond. Someone may have unlocked the numeric keypad, maybe some test code or service. First of all, Thanks. Quote Link to post Share on other sites
AUSCE Posted January 4, 2020 Report Share Posted January 4, 2020 On 17/3/2019 at 3:10 PM, jim2154 said: it didn't work on mine whats the easy fix? adal2154@gmail.com what is the fix ausce@hotmail.com, best regards. Quote Link to post Share on other sites
AUSCE Posted January 4, 2020 Report Share Posted January 4, 2020 On 23/2/2019 at 3:18 PM, DaveVdz said: I have an easy fix that worked just fine, leave you contact and I gladly share. what is the fix ausce@hotmail.com, best regards. Quote Link to post Share on other sites
Forrester83 Posted January 10, 2020 Report Share Posted January 10, 2020 cravatts you are a life saver. I purchased a vehicle where it was locked out because of the password. I did exactly what you said in your first post and it worked. I had the AVH-4200NEX. My jump drive was just formatted as FAT32 and i plugged it into the USB slot 1 and it read it after a minute. Quote Link to post Share on other sites
AUSCE Posted January 20, 2020 Report Share Posted January 20, 2020 On 9/1/2020 at 6:28 PM, Forrester83 said: cravatts you are a life saver. I purchased a vehicle where it was locked out because of the password. I did exactly what you said in your first post and it worked. I had the AVH-4200NEX. My jump drive was just formatted as FAT32 and i plugged it into the USB slot 1 and it read it after a minute. realy i do the same and still the problem... Quote Link to post Share on other sites
Makecome Posted January 20, 2020 Report Share Posted January 20, 2020 On 2/23/2019 at 1:18 PM, DaveVdz said: I have an easy fix that worked just fine, leave you contact and I gladly share. Interested in easy fix please Quote Link to post Share on other sites
AUSCE Posted January 24, 2020 Report Share Posted January 24, 2020 Take the file with a friend who handles linux, the * .iso files of the RAR are corrubtos barely occupy 86 bytes and could not be mounted as iso in linux. Greetings. Quote Link to post Share on other sites
