Torrie Posted November 27, 2017 Report Share Posted November 27, 2017 Thanks mate! Quote Link to post Share on other sites
variable.cabbage Posted December 10, 2017 Report Share Posted December 10, 2017 Your voodoo-black magic script worked like a charm. Quote Link to post Share on other sites
racer6489 Posted December 19, 2017 Report Share Posted December 19, 2017 Ok, sorry if this is a stupid question.   I bought a truck used that had the AVIC X910BT already installed. I lost the contact info from the guy I purchased the truck from and I now just have the password screen up. I've tried all of the generic ones to try and guess it with no avail. I used this script with an SD card but all it did was copy over a system file to the card that I can't open on Windows or MAC to read. I can't get to my Source button to just run the SD card to run the script to reset the passcode. Is there something I'm missing or doing wrong? Any help would be great. Thank you! Quote Link to post Share on other sites
Alexei Navalny Posted December 19, 2017 Author Report Share Posted December 19, 2017 On 12/19/2017 at 10:55 AM, racer6489 said: Ok, sorry if this is a stupid question.   I bought a truck used that had the AVIC X910BT already installed. I lost the contact info from the guy I purchased the truck from and I now just have the password screen up. I've tried all of the generic ones to try and guess it with no avail. I used this script with an SD card but all it did was copy over a system file to the card that I can't open on Windows or MAC to read. I can't get to my Source button to just run the SD card to run the script to reset the passcode. Is there something I'm missing or doing wrong? Any help would be great. Thank you! I'm surprised it worked on a X910, that's an older model. If the script worked it copied a file to SD called PASSWORD.DAT. Then it deleted the file from the head unit, which should unlock your unit during the next reboot.  Windows doesn't know what to do with a .DAT file. If you want to view what's in the file, right-click and select "open with" and choose Notepad.  On 12/19/2017 at 10:55 AM, racer6489 said: I can't get to my Source button to just run the SD card to run the script to reset the passcode. Is there something I'm missing or doing wrong? I'm confused - you just said you ran the script. What does "Source" have to do with it? Quote Link to post Share on other sites
Keilen Posted December 24, 2017 Report Share Posted December 24, 2017 I just downloaded your script and used it on my AVIC-F930BT, and it worked perfectly. Â Tried alot of different other sites, but yours was definetly the fastest, and most secure! Â Thanks a bunch Quote Link to post Share on other sites
spaul62 Posted January 20, 2018 Report Share Posted January 20, 2018 perfect!!!!! Quote Link to post Share on other sites
Mosti Posted January 21, 2018 Report Share Posted January 21, 2018 This is exactly what was required. Thanks. Quote Link to post Share on other sites
marius260 Posted February 3, 2018 Report Share Posted February 3, 2018 Worked great for f9220bt. Many thanks. Quote Link to post Share on other sites
Joe Cool Posted February 7, 2018 Report Share Posted February 7, 2018 Super! Thanks a lot! Quote Link to post Share on other sites
osxPitt Posted February 9, 2018 Report Share Posted February 9, 2018 WOOHOO I'm a hacker now! (thanks to your sweet little script, Thanks!!) Quote Link to post Share on other sites
KHirsch Posted March 13, 2018 Report Share Posted March 13, 2018 Wow.. I was lucky to find this. Couldn't find anything like this anywhere else online and was stuck after my battery became disconnected on my truck and recently bought it used with the aftermarket unit installed. I wasted a lot of time trying possible passwords and calling Pioneer who wanted to charge $80 just to send it back and take the password off. You have helped a lot of people!! THANK YOU! Quote Link to post Share on other sites
paskishow44 Posted March 16, 2018 Report Share Posted March 16, 2018 Hi, I have an AVIC F9210BT and I wanted to remove the existing password to be able to update it.Unfortunely, using this trick I finish with this screen. Can you help me? Thank you!!! Quote Link to post Share on other sites
Alexei Navalny Posted March 16, 2018 Author Report Share Posted March 16, 2018 3 hours ago, paskishow44 said: Hi, I have an AVIC F9210BT and I wanted to remove the existing password to be able to update it.Unfortunely, using this trick I finish with this screen. Can you help me? Thank you!!! Â It can't write to the SD. Is the write-protect on? Quote Link to post Share on other sites
paskishow44 Posted March 16, 2018 Report Share Posted March 16, 2018 2 minutes ago, RonS said: It can't write to the SD. Is the write-protect on? I don't think the SD card, I've tried with a another... Quote Link to post Share on other sites
Alexei Navalny Posted March 16, 2018 Author Report Share Posted March 16, 2018 On 3/16/2018 at 8:41 AM, paskishow44 said: I don't think the SD card, I've tried with a another... I am certain that the error is when the script is executing the command:Â Â COPY USER\SYSTEM\SECURITY\PASSWORD.DAT SD\PASSWORD.DAT That means it can't write to SD. There is the only one COPY command in the script. If you want, you can edit ScriptExec.ini and remove that line. In that case, you will not have a backup of the old password file, but that should not hurt. Â Quote Link to post Share on other sites
