Forpub Posted October 5, 2019 Report Share Posted October 5, 2019 Didn't work at first attempt. Solved it with the following : - I formatted the SD card using an MBR zone (in mac : $ diskutil eraseDisk FAT32 USBNAME MBR /dev/diskNode ) - I chmod 777 the files. AVIC-F930BT Quote Link to post Share on other sites
C17ffe Posted November 11, 2019 Report Share Posted November 11, 2019 (edited) On 9/20/2017 at 11:17 AM, RonS said: See original post Hi - this got me off the password screen and to the home screen on AVIC-F960DAB but then I took the USB out and it went back to asking for password? I should have reset password there and then...do I need to dO somet else? Edited November 11, 2019 by RonS Removed complete repost of opening post instructions. Quote Link to post Share on other sites
Alexei Navalny Posted November 11, 2019 Author Report Share Posted November 11, 2019 17 minutes ago, C17ffe said: Hi - this got me off the password screen and to the home screen on AVIC-F960DAB but then I took the USB out and it went back to asking for password? I should have reset password there and then...do I need to dO somet else? Sorry, I don't know anything about the F960DAB. Did you try this method? http://avic411.com/index.php?/topic/83592-security-password-removal-script-for-z110120130140-x920930940-some-older-f-series/&do=findComment&comment=348733 Quote Link to post Share on other sites
C17ffe Posted November 11, 2019 Report Share Posted November 11, 2019 1 hour ago, RonS said: Sorry, I don't know anything about the F960DAB. Did you try this method? http://avic411.com/index.php?/topic/83592-security-password-removal-script-for-z110120130140-x920930940-some-older-f-series/&do=findComment&comment=348733 I’ve just tried the anti theft service pass off and hidden button - on the link you just sent - it worked, and it even let me reset the password. thank you all who have posted over the years...wasted a bloody whole day today just to fit a reverse camera which the trip the fuse...hence password reset needed. Funny thing is I set the password 12 months ago and even gave myself a hint...which for the love of me didn’t have a clue!! phew...all done. Quote Link to post Share on other sites
piethorden Posted November 23, 2019 Report Share Posted November 23, 2019 Works perfectly and it even copies the old password to the SD-card! Quote Link to post Share on other sites
25yr.InstallVeteran Posted February 1, 2020 Report Share Posted February 1, 2020 I got it! The SERVIC PASS OFF worked on my NEX-5100....THANKS!! Quote Link to post Share on other sites
HighImAdam Posted February 15, 2020 Report Share Posted February 15, 2020 Made an account just to say SERVICE PASS OFF worked on my fathers "2015 Tundra with a Pioneer AVIC 5000NEX " he changed the battery after a cold snap and was greeted with the password screen which he completely forgot. FYI I had to type all letters in UPPERCASE and hold the "hidden button" for about 10-15 seconds before getting the unlocked prompt. THANK YOU ALL !!! Quote Link to post Share on other sites
nmaric1993 Posted March 29, 2020 Report Share Posted March 29, 2020 Worked for avic 940bt. THANKS!!!! Quote Link to post Share on other sites
cesschester Posted April 16, 2020 Report Share Posted April 16, 2020 A++++ Quote Link to post Share on other sites
rayfrombk Posted April 24, 2020 Report Share Posted April 24, 2020 worked for my 4200-NEX Thanks!!!!! Quote Link to post Share on other sites
genesisf23 Posted May 3, 2020 Report Share Posted May 3, 2020 Thank you! Bought a used vehicle with a locked unit. Worked for me and now I don't have to drop even more money just to use the radio. Quote Link to post Share on other sites
KerryQ Posted May 6, 2020 Report Share Posted May 6, 2020 AVH-4400NEX. I cannot access the SD card slot because the eject button seems to be locked. So I copied the 2 files to a thumb drive and tried that. It did boot from it but returned an error: FAILED STARTING! ERROR CODE : 5 [TURN OFF ACC] Tried several thumb drives, different sizes, all formatted Fat32 and all returned the same error. Thumb drives were plugged into usb port 1 on the unit via an extension cable. I did not feel like removing the unit from the dash but will gladly do so if anyone thinks that might make a difference. Or maybe it just won't work from usb? TIA Quote Link to post Share on other sites
Alexei Navalny Posted May 6, 2020 Author Report Share Posted May 6, 2020 10 hours ago, KerryQ said: AVH-4400NEX. I cannot access the SD card slot because the eject button seems to be locked. So I copied the 2 files to a thumb drive and tried that. It did boot from it but returned an error: FAILED STARTING! ERROR CODE : 5 [TURN OFF ACC] Tried several thumb drives, different sizes, all formatted Fat32 and all returned the same error. Thumb drives were plugged into usb port 1 on the unit via an extension cable. I did not feel like removing the unit from the dash but will gladly do so if anyone thinks that might make a difference. Or maybe it just won't work from usb? TIA It won't work on a NEX unit. Totally different systems. Try this method: Alternate method - service password screen. Quote Link to post Share on other sites
KerryQ Posted May 8, 2020 Report Share Posted May 8, 2020 On 5/6/2020 at 7:39 AM, RonS said: It won't work on a NEX unit. Totally different systems. Try this method: Alternate method - service password screen. I had tried that previously but it did not work. So I got desperate and purchased a solution off of ebay and it was the exact same thing. But I tried it again. Pushing and holding the top left corner did nothing but I tried pressing about an inch to the right and it worked. Quote Link to post Share on other sites
Bilbo1953 Posted May 15, 2020 Report Share Posted May 15, 2020 On 1/31/2019 at 3:38 PM, BlakeStone said: Wow! Nice share! Thank You, by far the easiest since the screen is staring at right at you. Must remember all the space commands or I assume this is linux based. At first I left off the final space command and it didn't work On 1/28/2019 at 8:00 PM, Ytumer said: As a follow-up; I had contacted Pioneer about my password issue and was waiting on a reply when I came across this thread. I thought I'd try the script instead of waiting for a reply, which worked perfectly for me. Turns out the Pioneer tech support team is extremely helpful. They sent through these instructions for me to clear my password. I haven't personally tried it as I had already run the script in this thread. If the script isn't working for anyone and you'd like to try an official alternative method to reset the password (not remove the prompt completely as this script does) please see the attached picture with instructions. I'm not sure which models this will work for as the reply to my email was specific to my AVIC F840BT. I'm sure other models with a similar password prompt will likely have the same procedure. I didn't think posting this would be more of an issue for theft than this script already is. Either method is easy and does the same thing so... Worked like a charm! Thanks! Quote Link to post Share on other sites
