LilRedExp Posted February 11, 2018 Report Share Posted February 11, 2018 Hi All! New to avic411.com and looking hopefully for the answers to my questions. I am currently finishing the re-install of my 5200 NEX in my 05 RAM 1500. When it was initially installed the speed signal input and reverse gear signal inputs were never connected. Can anyone tell me where to connect these wires on my RAM? Is the reverse gear input just looking for a voltage signal (i.e. reverse lights)? That one I can probably figure out but the Speed signal has me stumped. Can anyone out there help me? Thanks! Quote Link to post Share on other sites
bonee Posted February 12, 2018 Report Share Posted February 12, 2018 2005 Dodge/Ram RAM - North America DirectWire Vehicle Information All Products Item Wire Color Polarity Wire Location 12 Volts red (40A) + ignition switch, black 14 pin plug, pin 11 Second 12 Volts red (40A) (except SRT-10) + ignition switch, black 14 pin plug, pin 1 Ground (chassis ground) Starter yellow (except SRT-10); yellow/orange (SRT-10) + ignition switch, black 14 pin plug, pin 13; starter button, white 6 pin plug, pin 3 (SRT-10) Ignition pink/lt. green + ignition switch, black 14 pin plug, pin 3 Second Ignition pink/white + ignition switch, black 14 pin plug, pin 2 Third Ignition pink/yellow (12 AWG) (SRT-10) + ignition switch, black 14 pin plug, pin 9 Accessory dk. blue (except SRT-10); pink/dk. blue (SRT-10) + ignition switch, black 14 pin plug, pin 8 Second Accessory pink/yellow (14 AWG) (except SRT-10) + ignition switch, black 14 pin plug, pin 9 Third Accessory pink/yellow (16 AWG); pink/yellow (12 AWG) (except SRT-10) + ignition switch, black 14 pin plug, pins 14, 10 Keysense violet/tan - ignition switch, black 14 pin plug, pin 5 J1850 white/violet (PCI BUS) data data link connector, black 16 pin plug, pin 2 IMMO Data white/violet (PCI BUS) data Sentry Key Immobilizer Module, black 6 pin plug, pin 2 Power Lock violet/dk. green - 820 ohms driver kick, door harness Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays. Power Unlock same as power lock wire - 330 ohms Lock Motor lt. green 5 wire driver kick, door harness Driver Unlock Motor tan/lt. green 5 wire driver kick, door harness Passenger Unlock Motor violet/lt. blue 5 wire passenger kick, door harness Factory Alarm Arm violet/lt. blue - 644 ohms driver kick, door harness This will also do door locks. Arm/lock is negative trigger thru a 644 ohm resistor. Disarm/unlock is negative trigger thru a 1565 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays. Factory Alarm Disarm same as factory alarm arm wire -1565 ohms Disarm No Unlock see factory alarm disarm Parking Lights (+) white/yellow (L), white/gray (R) + harness at top of driver fender Parking Lights (-) white/lt. green (see Tech Doc 1082) - 270 or - 590 ohms headlight switch, black 8 pin plug, pin 8 Hazards white/orange - hazard switch Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay. Turn Signal (Left) use hazards wire Turn Signal (Right) use hazards wire Headlight white/lt. green (need to relay isolate from switch - 470 ohms headlight switch, black 8 pin plug, pin 8 Reverse Light white/lt. green + inside mirror or plug by PCM The PCM is on the passenger side firewall. Left Front Door Trigger violet - driver kick panel Use all four wires and diode isolate each. See Tech Doc 1076 for wiring information. Right Front Door Trigger violet/white - passenger kick panel Left Rear Door Trigger violet/orange - driver kick panel Right Rear Door Trigger violet/yellow - passenger kick panel Dome Light yellow/lt. blue or yellow/orange + driver A pillar or cluster Tachometer dk. blue/gray ac PCM, orange plug, pin 34 The PCM is on the passenger side firewall. On SRT-10 models, the tach wire is in the black plug, pin 18. On diesel models, the tach wire is at the ECM on the lower driver side of the engine, 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug. On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT brown/white. Wait to Start (see Tech Doc 1091) On the remote start, make sure to program the Accessory State During Wait To Start to ON. Speed Sense dk. green/yellow PCM, top black plug, pin 13 The PCM is on the passenger side firewall. On SRT-10 models, the vss wire is in the white plug, pin 27. On diesel models, the vss wire is at the ECM on the lower driver side of the engine, 50 pin plug, pin 11. Brake Wire white/tan + brake pedal switch Parking Brake dk. green/white - parking brake switch Horn Trigger dk. green/violet - horn switch Wipers brown/white (L), brown/orange (H) + windshield wiper motor Left Front Window (Up/Down) orange/lt. green - orange/white A driver window switch in door Right Front Window (Up/Down) orange/tan - orange/gray A driver kick, door harness Left Rear Window (Up/Down) orange/white - orange/gray A driver kick, door harness Right Rear Window (Up/Down) orange/lt. blue - orange/dk. blue A driver kick, door harness Sun Roof (Open/Close) motor part of module Radio 12V gray/red + radio Radio Ground black and black/lt. green - radio Radio Ignition pink/yellow + radio Radio Illumination orange/tan (dimmer) + radio Factory Amp Turn-on (PCI Bus) Left Front Speaker (+/-) dk. green/yellow - dk. green/lt. blue +,- radio or amplifier behind glove box, 14 pin plug The tweeter wires are gray/orange - gray/yellow at the amplifier, 20 pin plug. Right Front Speaker (+/-) gray/yellow - gray/lt. blue +,- radio or amplifier behind glove box, 14 pin plug The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, 20 pin plug. Left Rear Speaker (+/-) gray/lt. green - gray/dk. green +,- radio or amplifier behind glove box, 14 pin plug Right Rear Speaker (+/-) dk. green/lt. green - dk. green/gray +,- radio or amplifier behind glove box, 14 pin plug Center Channel (+/-) gray/brown - gray/orange +,- amplifier behind glove box, 20 pin plug Subwoofer (+/-) gry/brn - dk. grn/brn(1); gry/wht - dk. grn/wht(2) +,- subwoofer under driver side rear seat Item Size Depth Location Headunit DIN and a half center of dash Left Front Speaker 6 x 9 5.25 left front door Left Front Tweeter 4 left front dash Right Front Speaker 6 x 9 5.25 right front door Right Front Tweeter 4 right front dash Left Rear Speaker 5.25 3.5 left rear door Right Rear Speaker 5.25 3.5 right rear door Center Channel 2.5 top center of dash Subwoofer 10 under driver side rear seat Quote Link to post Share on other sites
gggplaya Posted February 16, 2018 Report Share Posted February 16, 2018 Forget all that, did you try the bypass method?? Quote Link to post Share on other sites
