bryansride Posted April 19, 2018 Report Share Posted April 19, 2018 Hi, I have an old 4runner and had a Z2 installed. The unit was bad, disc reader, Phone issues, Etc. I bought a 2300 NEX and installed it myself using the Scosche wiring harness adapters for my car. The back up camera works fine when I first start the car. However, I have to close the camera "Box" by Xing out of it. When I drive and then put into reverse, I do not get a back up camera. I can manually get the the back up camera by going to AV and selecting the rear camera and it works. Again, I have to exit out of the camera screen manually. I am using the "Top-tier" license plate camera sold on Amazon. The camera has a "trip"wire for the back up lights and a ground wire. It is hooked up to the reverse light harness at the back of car.,and grounded. I also have the AVIC back up "trigger" wire. However, attached to the back up wire harness or not connected, the camera does the same thing. I am wondering if I connect the back up camera "trigger wire" to the AVIC unit "trigger" wire if it would be the correct wiring. I did not want to wire it that way prior to asking here. Any help would be greatly appreciated . Thanks Bryan Quote Link to post Share on other sites
bryansride Posted April 21, 2018 Author Report Share Posted April 21, 2018 OK, We figured it out. The backup "trip" wire pigtail was not installed correctly on the back up light switch. It had a loose connection on the wire. Bad butt connection. replaced it and I rewired the back up camera and, the connection to the head unit "trip" wire. All good now! Quote Link to post Share on other sites
