AVIC-F960DAB stuck in boot loop
Hello,
Got a Pioneer AVIC-F960DAB UK model,
It was working ok until the battery went flat, Now it just cycles the boot screen, It shows the NAVGATE screen, then the pioneer loading screen, and repeats.
It never actually comes on,
I have tried some of the suggestions for entering test mode but nothing i try seems to do anything.
Can anyone help me with this problem?
Many thanks
Mark.
I have the same problem and tried all the steps suggested here, although I'm not sure I have the right test mode files, not sure if the test mode directory should be in the SD Card root or the contents of the test mode directory should be in the SD root, what other files if any I need.... Bit lost
I have a reversing camera fitted and AV out goes to screen in back of car. If I go in to reverse just as the splash screen comes up, I get a few seconds of
reversing camera view before it goes to black screen. After going to black screen, video plays in the back but without sound and the unit refuses to respond to
any controls.
Seriously doing my nut over this... Any help for me an original poster would be appreciated..
Jon
  • 3 weeks later...
  • 1 month later...
OK.. will try that - but what then...? Do I just have the .tst file in the root of the flash drive? Or the directory with the .tst in it. Also, do I copy it to a USB drive or an SD card?? And when I do get to test mode, what do I have to do to repair the built in boot flash..?
A bit lost, as most of the guides here and elsewhere assume knowledge I don’t have or are for differing models!
 Thanks for the reply above, I am going out of my mind with this!
  • 2 years later...
