On 5/29/2019 at 1:19 AM, asd255 said:
This is an SD card with a custom version of FW.
She will upgrade your AVH to AVIC
Only an SD card replacement is required.
The solution if you have problems with the SD card.
We can set the country of any country of your choice.
for W4400NEX you will get:
  • Navigation from the AVIC W8500NEX with the latest update
  • Weblink
  • parking lines
support model
  • Pioneer AVH-Z9100BT
  • Pioneer AVH-Z9100DAB
  • Pioneer AVH-Z9150BT
  • Pioneer AVH-W4400NEX
  • Pioneer AVH-Z9200BT
  • Pioneer AVH-Z9200DAB
  • Pioneer AVH-Z9250BT
  • Pioneer AVH-W4500NEX
How much does this sell for and who sells it?
  • 1 month later...
  • Replies 30
Does avh2avic retain the ability to use maestro rr? I ask because I have a 4500 with bad SD card and I replaced SD with one that I flashed with the 4400 image floating around (modified for resistive touch) and it brought the radio back to life but now maestro rr doesn't talk correctly to it even after re-flashing maestro and making sure that maestro is configured with the serial number. Same SN on label and on-screen so flash didn't seem to affect SN.
If avh2avic does function correctly then maybe I'd be better off paying for that.
Thanks.
On 8/21/2019 at 12:50 AM, asd255 said:
I do not see the point in updating the W4400 to the W4500.
Weblink is another dead-end application.
there’s nothing useful except watching YouTube videos.
not an original player is used for viewing, this is very bad.
It makes no sense to buy a 500 series, it’s enough to buy 400, I didn’t notice any more changes, except that I added the ability to display parking lines on the camera. It is strange that they removed it for x400, because this function is available for the European model of analogues x400.
But there is a great solution to upgrade the AVH-W4400 \ 4500 to AVIC with full navigation support. If interested, write to me at PM
I did not update the firmware in my W8400 to the W8500 version.
i need a solution to upgrade my AVH-W4400
  • 4 months later...
  • 2 weeks later...
Does anyone know if this mod will work on my AVH-X8850BT?
Confirmed Test Mode works and made a backup of the internal SD.
Seems to be a 4gb internal so i am thinking i will need to get an 8gb to fit maps and such?
How would i go about installing a GPS antenna to support GPS functionality.
  • 1 month later...
  • 1 month later...
  • 5 months later...
  • 2 weeks later...
  • 4 months later...
Hello asd255 I bought the avh2avic to fix and upgrade pioneer boot loop on 4500nex .. about a year ago amd just installed in radio which worked as promised however issue I'm having is that I cannot get maestro to work .you had sent me the instructions which I've lost .pr
On 7/14/2021 at 3:43 PM, asd255 said:
MaestroRR is compatible with AVH2AVIC
but you need to reprogram MRR
The original s/n number is not working on mrr I had instructions you sent no clue where they are..any way of getting the instructions again that you send out when people purchase the sd card.
  • 1 month later...
