7100NEX Firmare Update Issues
I've been trying to update the FW on my 7100 from 1.05 to the current. I went to Pioneer's site DL'd the current FW. Following the instructions, unzipping to USB and so on. When I tried to install,via the "Settings" > "System Info" "Firmware Update" I get a file error "Please connect a USB or SD card containing only the update file". There are 12 folders on the drive and 13 files in the root of the drive. I have tried with 1.09, 1.10 & 1.11 with the same result. Am I doing something wrong here? Should I even update?
Any insight/help is much appreciated.
Thank you, bonee. I have done exactly this a few times with different USB drives (Sandisk, Adata), and i get  the result quoted in my 1st post. Below is a screen shot of the root of the USB drive. Looks to be the same file structure on the different versions of FW.
