Same harness for NEX8200 as NEX5000?
I have an NEX 5000 and since a couple firmware updates ago (can't remember which one), part of the screen is unresponsive intermittently and requires repeat touches to acknowledge. Therefore, I'm considering buying a used 8200 and I'm wondering if this will be a pretty simple swap? It looks like most things have the same exact connection, GPS antenna, remote, etc. But I'm mainly curious if they're using the same harness where I could just simply wire the speaker connections and plug the 8200 in with the existing harness.
Thanks in advance!
  • 2 weeks later...
  • 3 weeks later...
Thanks a lot. That's good to know. I don't believe the 8200 I bought comes with anything other than the wiring harness which I won't even need since I'll use the existing harness...so I don't think the remote wiring would even be an issue. If he does send it, I'll consider using the 8200 harness and rewiring.
