AVH-4400NEX Software Error
  • 3 months later...
  • 2 months later...
I am also trying to find the image file for the AVH-W4400NEX, however even if I find it, I tried to access the SD Card (if it ever exists) and it is insanely difficult it find it. There are a bunch of screws, and if you loose one of them, you are screwed. Has anyone got to find the SD card on this unit?
  • 2 weeks later...
The location of the SD card with the image is behind the faceplate. Had to remove 6 Phillips screws and manually pull out the eject mechanism. Have to remove the ribbon cable to the board that connects to the faceplate as well.
its right below the accessible SD card slot.
now to find an image...
  • 1 month later...
Bux, were you able to find the image? I have this model as well.
  • 1 month later...
For what it's worth I just repaired mine.  Followed the instructions from the poster Bux.  Thank you Bux!!!  Not difficult at all.  I could not find an image on the net for free so I purchased one from ebay.  I could live with the $35 cost as opposed to the $200 plus Pioneer wanted to charge.
  • 3 weeks later...
  • 2 months later...
Was hoping that I didn’t have to remove the radio, but I guess I do.
On 10/16/2019 at 4:45 AM, BTNOTTRUE said:
Will this downloaded on a SD card work?
