Jump to content
AVIC411.com
CNDV-70R hack
  • Replies 39
  • Created
  • Last Reply
Top Posters In This Topic
Interesting how your system boot and drive core are newer and my drive app is newer. I was curious what would happen if you used newer voice files, if they actually got used at all.
The versions are different because of the different models. From what I can tell the OS, gps, application, and language data are the only stuff to change with the system updates.
I have not driven much, but the turn by turn directions seem to be working 100% with the updated voice files.
This is the avic-9dvd
System boot version		1.02
System OS version		3.03
GPS program version		2.70
Application data version	4.000004
Language data version		2.00102b
Syscom version			8.00
Drive core version		28.00
Drive apl version		8.31
TV ucom version		8.06
System language		UC010SYS.USA
Application language		UC010DAT.USA
This is the avic-80dvd
System boot   			3.02
System OS   			3.03
GPS Program   			2.70
Application    			4.000004
Language data   		2.00102b
Syscom version     		8.00
Drive Core   			33.00
Drive apl.   			 8.19
TV Ucom      			8.06
System Language  		 UC010sys.USA
App. Language   		UC010DAT.USA
This is the avic-90dvd
System Boot 			2.01
System OS 			3.03
GPS Version 			2.70
APP Version 			4.000004
LANG DATA 			2.00102b
Syscon Ver 			8.00
Drive Core Ver 			30.00
Drive Appl Vers 			8.31
TV UCCOM 			8.06
SYS lang 			UC010SYS.USA
APP lang 			UC010DAT.USA
Not much has changed on my end; I have only added the avic-9dvd into the system. At this point I am kind of waiting to see what will happen with a SD card adapter. I have done some research on the Mercedes-Benz forum about what SD card adapter has worked in their factory navigation systems. The avic and from what I can tell most factory navigations use the Denso company for the navigation unit, so I figured if a SD card adapter works on their units it might work on ours. I have gone ahead and ordered the adapter that they recommend, but it is coming from Hong Kong and can take up to 14 days to get here.
One other problem that I have been having is with my avh-p6400cd. Awhile back, for about a week my unit had trouble closing, I would have to guide it down. The other day while I was installing the avic-9dvd, before I put both units into the dash I checked to see if the avic-9dvd was working. When the avh opened all seemed fine, but when I put it down I heard grinding. Now the unit will not go down at all without my assistance. I have gotten my hands on the service manual so that I can order the gears and replace them. So now I have to take out the avh again to take it apart and find out what gears I need to order, at least most of them seem to be only $2.50 each. Here is a link to the service manual just in case you ever have a problem.
http://www.filehosting.org/file/details/64849/pioneer_avh-p6400cd_p6450_crt2853__ET_.pdf
Great info!
Did anyone figure out how to disable the startup warning screen yet?
No, I have not figured that out yet. I have just started looking into it and already made myself a lot of coasters. I have found the wording for the warning in the UC010DAT.USA file, but not the programming command that calls for it. It seems that once I change anything in the dat, sys, or apl files the system does not like the disc and asks for the appropriate disc upon a restart. The hard drive navigation systems have the warning located in the apl directory. I have not been able to locate it, so I don’t know if it is in the alldate.wki, sys, dat, apl, or in the file system on the unit its self. Once I get a working SD card adapter and do a file system dump on the unit, I might be able to locate it. Also, if I can get a SD card adapter that will load the system on it I will not have to go through so many discs. I have been using my test version that fits on standard dvd+r discs so that I am not wasting pricey dvd+r DL discs. I have been able to drive around town without any problems in the mapping system, the POI and telephone information was the main stuff that I removed from the IDX folder.
Here is a link to the east IDX folder that I use to slim down the CNDV-90r to fit on a standard dvd+r disc for testing if anyone wants to help out in the testing.
http://www.filehosting.org/file/details/64855/IDX.rar
Here is a link to an iso of my whole 90r test disc, this is once again the east version
http://www.filehosting.org/file/details/64882/90R_Test.rar
Link to post
Share on other sites
  • 6 months later...
I'll be testing out a version of the CNDV-90R-East shortly. I'm trying to take as much as possible from the 80MT and 90MT and then overlay the needed pieces from 40R.
Some other threads about hacking these disks for different DVD units.
http://www.avic411.com/forum/viewtopic. ... &start=375
http://www.avic411.com/forum/viewtopic. ... 70#p118570
Also, I think this is the main NEC chip:
http://www.necel.com/cgi-bin/nesdis/o00 ... e=RX705100
from the uc010*.prg files
Copyright © 2001 PIONEER Electronic Corp.
RX705100 Copyright © NEC 1996-1998
Link to post
POINT directory is same on 90MTE and 40RE
SKY directory is same on 90MTE and 40RE
MARKTP - doesn't exist on 90MTE, took it from 80MTE. did not use 40RE as I did on 80R -<< check works -- I reverted to using the marktp from 40RE as I had some graphic issues-- but that might be because of a messed up dvi.dat file. Note sure. My 70RE used the updated files from 70MTE. Test again when 100MTE comes out.
SNDDATA - used 40RE on 70R
Used the 040snd only files from 90MTE. 80MTE and 90MTE have same uc040snd files.
801e30abe6c0055450f4071c5d17e65d ../../90MTE/snddata/uc040snd.esp
84932743b7906a01806fed0437c4c8ff ../../90MTE/snddata/uc040snd.fra
6a930a714590db2acd0c2dac0324ff01 ../../90MTE/snddata/uc040snd.usa
VOICE - used the 80MTE voicetp uc010vdc* files.
701 and 801 don't have VOICE dir, they have VOICETP dir and the files differ between 70MTE and 80MTE.
IDX - took entire 90MTE tree, no merge
BG - changes and merges
90MTE and 80MTE are identical in bg and bg2 except the bgopen files
copy 90MTE bg directory to 90R
copy 40E to 90R dir
took 40E bg/*.hcs files
Took all the 90MTE /bg/pim529/ files to 90RE/bg/pim/ (pim529 are idential to 40RE bg/pim/*.pim files except 90MTE has two additional *2.pim files.
bg/pinanime/*, 40RE only has city file (identical), but I copied them from 90MTE
15ca2d54697c1ffdb90af0a7dedc7da1 city.pim
be7d57ee4f6d0bce21634c285d962ca7 skyline.pim
cdc53dd8ee9ccfac3ac0ce893d9088fd twilight.pim
remove the pim529 directory
in root:
copy all from 40RE
uc010*
ucz*
for my 2nd try on 90RE I used the ucz files from 90MTE.. apparently this is how I did the 70R - confirmed, using 90MTE ucz files.
eu*
These files are identical on 80MTE and 40R, 90MTE doesn't have *10* files.
40R has uc010dat files, 801 had uc010dtt files
916c96f66fb3d4a6414e1dba6f7d8f3c uc010gps.htm
d46c8e4991c88094f81825f49aa0b4fa uc010gps.prg
509bbb3fa0e6ac69386cf8c0459a5b03 uc010sys.esp
8bb3550b409b3a8c98bf773111d6adaf uc010sys.fra
739aec8e5a8854d38eef77d6cd1058b4 uc010sys.htm
0524a112bfbb53c7bc532085dcefd89f uc010sys.usa
From 90MTE:
alldata.kwi indexdat.kwi kgrpdat.kwi landmark.kwi metadata.kwi rdstmc.kwp region.kwi
Or if you are lazy, just take the IDX directory and the files just above and put them on a 40R and you are golden.
Link to post
  • 6 months later...
For the CNDV-100R I think I will try to get the system to boot off flash.
Since 8GB and 16GB flash card are dirt cheap now...
While poking around the diagnostics menus on the AVIC-90DVD, I backed up the SRAM to the flash card.
I then looked at that binary file and it seems to be some sort of DOS file system... even my Unix system thinks so:
file FILE000.RAM
FILE000.RAM: x86 boot sector; partition 4: ID=0x49, active, starthead 1, startsector 1394627663, 21337 sectors, Microsoft Windows 98 Bootloader, code offset 0x3e, OEM-ID "PIONAV03", FAT 1, root entries 64, sectors 440 (volumes <=32 MB) , sectors/FAT 2, serial number 0x3d668ea2, unlabeled, FAT (12 bit)
Hmmm... this is only a 220K file and I think the SRAM is limited to 256K (from the diag menu), but the specs at Pioneer say this has a 32MB SRAM system 32MB is a lot of space to stuff a nice OS. hmmm..
Link to post
Well, I copied the 40r basic stuff to a 48mb flash card. Then shoved in the 100MTE disc and presto it all works. It seems to look for needed files off the DVD drive first then if it can't find them will look for them on the flash card. Since the 100MT disc no longer has OS files for the avic 80/90 DVDs it looked to the flash card to find them. What led me to that was on occasion the DVD drive won't read a disc and says to insert the appropriate one. Well, last time it started acting up like that I put in the flash card and it booted up the old screens from 2005 with no map data.
What's this mean? That means all of you people with avic 80/90 NAV systems just need to copy off some files from your last working Nav disc to a flash card then use the latest cndv-100mt discs and you have updated maps. Now I think the last touch screen code was on the 80MT and the last remote control code was 40R. Those of you with remote control units don't put anything in other than the latest 100 or your system will be upgraded to touch code. 90MT might work too, but I haven't checked to see if the OS for the avic 80/90 is still on there.
Hmm anyone want to give me a old touch screen head unit so I can get rid of this remote control system? :)
Link to post
  • 1 month later...
for the rest of us remote system users which files need to be copied for the 40R to a flash card in order to use the 100MT (west)?
Link to post
  • 5 weeks later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
