Hack change ragion pioneer avic F/X series
Gift for March 8
I personally prescribed a hack for russification and disabling the password, be careful, everything you do at your own peril and risk
Tested more than once and still works, with all the latest firmware
Instructions;
1 Will be updated to the latest firmware version, preferably above 3.0, work is not guaranteed on earlier versions
2 Before flashing, make sure what type of device you have by default in the Apl folder script for versions F30,40,930,940 for other devices F10,20,920 replace the AplLib file from the Apl10,20,920 folder in the Apl folder
3 After that, we throw all the files into the root of the map, the script will start automatically
4 If you need to unlock the device, then we put only the Password folder in the SD root, delete the rest of the folders
https://mega.nz/folder/x6o2xY5Y#mEl03n0IKDo_JkjNU0o6Dg
P.S. Do not forget to say thank you, during the development of the script one 930 was "killed", it's a pity, but as they say .....
and I almost forgot the rest of the languages of voice prompts will not work only Russian, there was no need to implement the rest
archive password author name
  • 2 weeks later...
