idbl_fanatic Posted November 30, 2007 Report Share Posted November 30, 2007 Mine did the same thing, when you upgrade again, if you have this problem, if you have anything connected via the data cable (im drawing a blank on what it's called) ie XM radio disconnect it and see if it works. I bet it does. This is what happened to me. I can't remember what exactly I ended up doing, but I know that I reset the XM unit, checked all my wiring, and reconnected everything AFTER the upgrade, and even had to send a re-activate code to my XM unit, and it finally started working. ps, feel free to email me with any more info, for some reason my spam filter blocks notifications from this forum, and sometimes I get them, sometimes I dont Quote Link to post Share on other sites
vertical_limit Posted December 9, 2007 Report Share Posted December 9, 2007 CAN SOMEONE EMAIL ME THE DOWN GRADE MY SYSTEM WONT WORK AT ALL WITH THE 70M UPGRADE ALL I GET IS A SCREEN SAYING TO PUT THE CORRECT DISK IN AND NOW I DONT GET ANY THING ON TH SCREEN fordfamily@hotmail.com THANKS Quote Link to post Share on other sites
curious Posted January 20, 2008 Report Share Posted January 20, 2008 mine does this as well with the copied discs...seems to be the burnt discs. After a while they seem to not let you do address searches. It is just a bad burn. Quote Link to post Share on other sites
ramman949 Posted February 26, 2008 Report Share Posted February 26, 2008 I got a MDS file of the upgrade disk. Burt it in alcohol 120 and it updated my system. I then realized the upgrade erased my boot up and background photos. I added them to the upgrade disk and the D2 wont accept the disk. It loaded he bootup photo, but says wrong disk if I try to go into settings. I also unplugged my XM before upgrading. This sucks! Anyone? Quote Link to post Share on other sites
mseller Posted August 4, 2008 Report Share Posted August 4, 2008 i tried three times today to burn this image via alcohol twice and power iso once and all three times my d2 says please insert appropriate disc...can some1 who burnt this successfully tell me what they did? EDIT: sorry i didn't read all related posts b4 posting and i found this post http://www.avic411.com/forum/viewtopic.php?t=8959&postdays=0&postorder=asc&highlight=cndv70mtp&start=30 ...i didn't check the boot option when i burned and i was using memorex discs...i will try verbatim discs and checking this option tomorrow Quote Link to post Share on other sites
