alex_s817 Posted May 25, 2008 Report Share Posted May 25, 2008 alright so i just got my d3 all hooked up and did the bypass. for some reason, there is no sound when using the ipod, a dvd, or a cd. the radio and navi functions both have audio though. does anyone have any ideas as to what would cause this? something i hooked up incorrectly maybe? the dvds play on the screen but the sounds just doesnt work. same for cds. thanks Quote Link to post Share on other sites
HiFiSi Posted May 25, 2008 Report Share Posted May 25, 2008 Are you using an external amplifier for your speakers? If so, you probably used the power antenna wire instead of the system remote wire for the amp turn on signal. To fix it, go into the menu and set the power antenna output to constant power: AV MENU > SYSTEM > ANT CONTROL > set it to "POWER" instead of "TUNER" Quote Link to post Share on other sites
alex_s817 Posted May 25, 2008 Author Report Share Posted May 25, 2008 yea thanks that worked. Quote Link to post Share on other sites
con5tant Posted May 25, 2008 Report Share Posted May 25, 2008 this also fixed mine. thank you!! Quote Link to post Share on other sites
viggen2 Posted December 1, 2008 Report Share Posted December 1, 2008 Had mine out for mounting modification. No sound on XM or CDs after re-install. Thanx HiFiSi for the heads up! Works fine now. Quote Link to post Share on other sites
Join the conversation
