Jump to content
First Impression. PICS now available...BMW X5
  • Please log in to reply
35 replies to this topic
#1 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 15 August 2009 - 03:13 PM
For the last 3 weeks I have had the HU in my house set up but the last 2 14 hour days I spent installing it in my BMW X5. I spent about 10 hours of research over the internet on how to get this done since the radio tuner was in the rear of the car.
2003 BMW X5
Old setup:
OEM Nav
OEM Amp
CD Changer
EAS video module (For reverse camera and DVD player)
Motorola HF1000 Bluetooth car kit
IntraveeII Ipod adapter
New set up:
Z110BT
HD tuner
MSN tuner
XM Tuner (Still to come)
2 Kicker Amps
2 sets of component Kicker
PAC-SWI-PS
The Install:
The install is very difficult due to the radio tuner being in the rear of the vehicle. Running all the wires including RCA for the amps, IPbus, 2 Antenna cables through the middle of the car was a lot of work. The driver seat had to be removed along with the rear seat and door sills.
The GPS antenna was placed behind the speedometer under the dash. There was an air duct with a flat surface and signal from there was perfect.
HD radio tuner is under the rear seat but the MSN tuner has to be placed near the HU since it is powered by it.
Amps were installed in the factory locations and are hidden from view along with the sub.
HU First impression
The screen is much brighter than the OEM nav. The sound is much clearer even when I had the factory speakers in. The OEM amp had built in crossovers that limited the speaker output.
The navigation was not accurate yet but I think this gets better since it still needed to finish calibrating. The Nav screen is a little confusing at first when slecting what screens to use.
The Ipod controls are great. Instant reaction time and the Video quality is good. If you have a large ipod then creating the VR dictionary may take longer but if dont unplug it then next time you get in the car it will take only a few seconds.
The bluetooth is okay except for trying to get back to the phone screen to hang up takes a few clicks. The Mic needed to be placed about 14" away from the face and cannot have anything covering it. I placed the mic in the original mic location for the BMW so its hidden from view but I was told it missing treble or I sounded like I was muffled. When I moved about 10" away from the mic it was crystal clear. The OEM mic location is next to the garage opener on the ceiling above the rear view mirror.
Issues:
I think that when I turn the car on the steering wheel control sends a signal to press the source button. Whenever I turn the car on the HU is on the next source. It is not consitent but it does happen. I might just reprogram the SWI to the use that button as a mute or End call.
The SWI-PS can be programed to use the track up and down on the steering wheel. The problem is programming it to Preset +/- does not affect Ipod controls. You must program the SWI-PS to Seek +/- instead. This creates an opposite problem where the radio goes up/down one freq at a time instead of using the preset.
Thats it for now. I will post the pics tonight. Thanks.
#2 Lash
Lash
  • Members
  • 10 posts
Posted 16 August 2009 - 12:45 AM
Thank You!
Please keep it coming. :^>
#3 Scott8659
Scott8659
    Member
  • Members
  • 31 posts
Posted 16 August 2009 - 03:25 PM
I will be doing a similar install on my 2005 M3 in a few weeks. My radio is also in the rear which makes it a big pain. The E46 series also do not like double din installs so I have to do some HVAC mods. Not looking forward to it but in the end I think it will be worth it. My current Dice iPhone solution is buggy at best.
Curious though. Doesn't your X5 have a little talking head button on the steering wheel? After reading the latest PAC instructions it indicates you can program this for phone accept and disconnect.
#4 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 17 August 2009 - 12:52 PM
The install was definitely a pain in the butt to do but definitely worth it. Huge sound improvement even with factory speakers.
The new SWI-PS works 95% of the time. I can live with the 5%. Now as for the programming I had to modify it a little bit from my original setting. The documentation states that the R/T (BMW Source button) cannot be used or programmed. During the initial install I was able to program it to the source command for the HU. For some strange reason the car would hit this button when I turn the car on therefore the HU always plays the next sources from where I left it. Not cool since it cycles through every sources available for each time it is pressed.
The solution was to use this button for something that will not be affected at start up. The new SWI-PS has 12 functions (Phone menu, Answer call,End Call) and Phone menu is the best option I could find for this button since it will not have any affect on the current source playing.
Phone menu will bring up the screen that displays all of phone functionality (Missed calls,received call, etc).
The button that has a face speaking is programmed to answer calls. I believe on the old Z series the button for the answer call and voice recognition is the same on the SR100 Remote. Unfortunately the Z110BT this function is different so that button is strictly used for answering calls.
Other programmed buttons are Vol +/- & Seek +/-. Read my original post about the seek or preset programing in case you are using an ipod.
FYI - I have read that BMWs with OEM bluetooth installed will require a little bit more modification to install the PAC unit. At least for the X5 it was.
#5 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 17 August 2009 - 01:35 PM
Some teaser pics. I will post miore later.
The Home depot galvanized L bracket fit perfect for BMW opening.
Shot while still set up in dining room table. mybimmer.net ABS bezel
Posted Image
Cutting the hole for OEM knob to be used for a the kicker bass knob and a rotary switch.
Posted Image
Fresh cut. before installing I colored it with a black sharpy. (Forcep bit was used)
Posted Image
Knobs installed
Posted Image
This is not my original nav but the OEM NAV looks like this
Posted Image
Side shot
Posted Image
Notice that the pioneer name is no longer on top and the chrome strip alon ghte bottom is gone. I just used a matte black decal from ebay to cover it up.
Posted Image
Kicker bass knob opened and filed down to fit into OEM Knob
Posted Image
Test Fit...
Posted Image
More to follow...
#6 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 17 August 2009 - 01:50 PM
More test fitting
Posted Image
HU Test fit. I needed to move the bracket up to fit the factory screws. Wood clear coat was lightly scratch but a little wipe removes it.
Posted Image
OEM Nav removed. Huge opening.
Posted Image
Bracket moved up to line up to the factory Holes.
Posted Image
Posted Image
Notice I used silicone for the knob installs. Its done in case it breaks or needs to be swapped out later.
Posted Image
Posted Image
#7 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 17 August 2009 - 02:03 PM
Fun day...The Install started.
Running wires took about 5 hours since many parts needed to be loosened or removed. Also since the OEM tuner was in the rear all the wires need to be run along with the RCAs for the amp and reverse camera. The power seat harness was not disconnected since I heard that this will require the dealer to reset the airbag lights.
Posted Image
Wires/cables are run through the middle of the car. The red cable is the Monster 6 channel RCA cable. It looks like a 4 guage power cable.
Posted Image
Screwdriver used to give room when lifing the carpet.
Posted Image
Power, antenna and HD tuner. HD tuner is currently placed under the seat but it will be relocated to the rear by the spare tire. This was a pain to install since the OEM antenna cable is in the rear. I needed to run 2 long antenna cables since the MSN direct needed to be in the front. The connection is in this order: From OEM antenna to MSN direct to HD Tuner. Antenna ends there since the signal is then passed into the head unit via the IPBUS. The HU antenna jack is not used.
Posted Image
Climate control removed and the wires HU wires behind
Posted Image
Wires tied together.
Posted Image
#8 Kingdaddy
Kingdaddy
    Member
  • Members
  • 47 posts
Posted 17 August 2009 - 05:34 PM
Great photos - good job!
#9 sdsurfer
sdsurfer
    Member
  • Members
  • 52 posts
Posted 17 August 2009 - 09:53 PM
Congrats on the new setup ,the custom job on the knobs is great ,it looks like stock .
#10 Scott8659
Scott8659
    Member
  • Members
  • 31 posts
Posted 18 August 2009 - 12:53 AM
Looks good. What gauge wires did you use to extend the harness to the back?
#11 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 18 August 2009 - 01:10 AM
I used 14 guage for power, 16 for accessory and amp remote. I ran 2 additional wires for future use that is 14 Gu. In addition the reverse trigger was also ran along with an antenna remote wire.
More pics coming soon.
#12 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 18 August 2009 - 03:32 AM
Here are a few more pics...
GPS Nav antenna placed on the air duct behind the speedometer under the dash.
Posted Image
VSS wire plugged in behind the speedometer.
Posted Image
Taking apart upper console for mic placement and removal of motorola BT kit mic.
Posted Image
Relocated the sunroof switch to the other side to mount the HU mic closer to me while using the OEM mic cap.
Posted Image
Posted Image
Mic mounted in left most space
Posted Image
SWI-PS connected. Original wire is cut to connect the SWI.
Posted Image
Wire tapped all speaker connections to 8 speakers. The car has 10 speakers but I am only using 8 and they will be going through a kicker passive crossover. Kicker amp below is used for the Subwoofer.
Posted Image
Crossovers. Note the battery is below. Picture is located on the back left of the vehicle.
Posted Image
#13 fe342185
fe342185
    Member
  • Members
  • 72 posts
Posted 18 August 2009 - 03:44 AM
4 Channel amp installed. Sub amp installed directly below it.
Posted Image
Finally fully installed picture.
Posted Image
Two and a half days of installing and I now can finally relax and enjoy it. Headrest monitors installed and pictures to follow.
#14 CamelTowing
CamelTowing
    Established Member
  • Members
  • 1206 posts
  • LocationFairfield, CA
Posted 18 August 2009 - 05:57 AM
Nice work. Looks OEM to the naked eye
#15 Scott8659
Scott8659
    Member
  • Members
  • 31 posts
Posted 18 August 2009 - 03:06 PM
Did you need any special tools to remove the OEM nav monitor and DVD drive? I noticed EAS sells special tools but I wasn't sure if they were necessary. Also, how did you connect the OEM antenna? I've read on other forums that the blue wire on the Pioneer harness is not used on BMW's. I know I need an adaptor and antenna extension cable but it needs power correct?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
