Jump to content
FX3.1 Complete Firmware Image
  • Please log in to reply
796 replies to this topic
#1 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 09 May 2010 - 08:00 AM
Hello everyone. This is an open message to those of you PMing me over the years with questions. I am pleased as punch that this is still used years later. I do need to say though, that I don't have any means of supporting FX3.1, so there isn't a reason to message me we with questions. I no longer own an AVIC or even a car. I do like receiving the thank yous though :) How is the status on the torrent? Does it need a reseed? If so I would be more than happy to include the newest maps. :P (09/05/2011)
Okay so what I've done is simple, I took what I considered to be the basic mods that would be appealing to almost everyone, without drastically changing the look and feel of the system.
This download contains:
Windows CE firmware
X Series 3.0201 update
Complete TA 2009.6 Map Upgrade (USA & Canada)
No nag screens
POI Branding
Speed camera/red light mod
Software speed bypass
Download: <!-- m -->http://thepiratebay....torrent/5546342<!-- m -->
You need only a single SD card, at least 2gb in size. Copy the entire contents of the RAR file to the root of SD card.
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
7. Press and hold reset for 5 seconds.
8. Select your language and voice options.
9. Enjoy FX3.1 :)
Tested on AVIC-f90bt. 05/08/10
FAQ:
How do I extract this rar thing?
<!-- m -->http://www.rarlabs.com/download.htm<!-- m -->
In test mode it says there isn't enough space to copy the files, how come?
This means you didn't select the SD format option in step 4, select everything on the "flash disk" and delete it, then copy your new files over
How do I know if my download completed properly?
The reason I stored everything in the RAR is because Winrar checks to make sure the download is perfect, if it didn't download properly, you would receive an error when extracting.
My unit just keeps booting to test mode?
Take your SD card out and then reset.
Why did my unit take so long to start the first 2 times?
That is normal, all the software is adapting to your AVIC
#2 shaker281
shaker281
    Member
  • Members
  • 21 posts
Posted 09 May 2010 - 11:26 AM
Let me be the first to say thanks. And good move posting as a torrent on TPB. I'm on the torrent and hoping to test my new Media card writer and 8 Gb SD card ASAP!
#3 shaker281
shaker281
    Member
  • Members
  • 21 posts
Posted 09 May 2010 - 11:29 AM
To be clear, Should "Copy the entire contents of the RAR file to the root of SD card.", read "Copy the entire "extracted" contents of the RAR file to the root of SD card."
#4 Jfinley0
Jfinley0
    Member
  • Members
  • 212 posts
  • LocationShoreview, Minnesota USA
Posted 09 May 2010 - 11:48 AM
I tried to open the file but it says "Unknown" or damaged file.
How do open it? I use WinRar.
Jimbo
#5 shaker281
shaker281
    Member
  • Members
  • 21 posts
Posted 09 May 2010 - 12:35 PM
OK, finally got a seeder! Keep seeding folks.
#6 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 09 May 2010 - 04:03 PM
My desktop is currently having an issue staying on. It randomly reboots, which requires me to manually start uTorrent, if the seed disappears just wait and it'll eventually come back online. As of now it should be seeding. 8)
#7 shaker281
shaker281
    Member
  • Members
  • 21 posts
Posted 09 May 2010 - 04:13 PM
Thanks.
#8 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 09 May 2010 - 04:16 PM
@Jimbo, that means you either didn't finish downloading (likely) or it didn't download properly.
#9 clean400
clean400
  • Members
  • 2 posts
Posted 09 May 2010 - 06:52 PM
Thanks!!!! I just finally installed my unit and this is exactly what I was looking for. Big Thumbs Up :D 8)
Edit: This should probably be a sticky. It's great for new users like me.
#10 kpob46
kpob46
  • Members
  • 10 posts
Posted 09 May 2010 - 10:41 PM
Yeah wow, great job Retell :D
#11 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 09 May 2010 - 10:49 PM
Thanks guys. Hopefuly this will turn on a new wave of modders by being so easy to install. This was also meant to be like an unofficial service pack to quickly help those of us who have failed avic experiments and require a quick method to get it back to our liking. :)
#12 Jfinley0
Jfinley0
    Member
  • Members
  • 212 posts
Posted 09 May 2010 - 11:27 PM
Jimbo
I kept trying to download it and still same thing. Is there a special way to open the file or different program to open this?
It only downloaded 17.7K
Jimbo
#13 tommyis3
tommyis3
    Member
  • Members
  • 34 posts
Posted 09 May 2010 - 11:56 PM
Anyone gonna seed this please.
#14 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 10 May 2010 - 12:15 AM
Jimbo
Jimbo
I think you need to learn how to use torrent.
My desktop went down again. Restarting in 10min.
#15 Retell
Retell
    Member
  • Members
  • 109 posts
Posted 10 May 2010 - 12:37 AM
Seeding again, it looks like about 25 of you are at 57%, I'd appreciate if just like 10 of you guys will help me seed for a week or 2.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
