i have a 2000 honda accord trying to install JVC KD-NX5000 but i am having trouble locating the vss and reverse signal wire for the gps thanks in advance
Posted Dec 24, 2007 · 08:21 UTC#1
reverse is green/black at drivers side fuse box
vss is blue/white at the ECM
Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total.
did u find it?
Is this the same for all Accords, including V6?
