I've wasted several DVD's trying to make a disk from this torrent and this is what I had to do to finally get the seach and POI's working.
1. Save the torrent file in a folder only one level from your root drive (C:\)
ie - C:\Software\PIONEER_CNDV_70MTP_WEST
2. Extract file in the same folder using WinRaR only
3. Burn your Dual Layer DVD using the latest update of Alcohol 120% at the slowest speed possible.
Also the Verbatim DVD+R DL seems to be the only disk I can get the burn to work correctly on as well. I have no idea why, but I am thinking for some reason it's the only brand the head unit is able to read both layers correctly from. I've checked the other brand's of dual layer disk I've used and they were all perfectly intact, however they only half ass work in the head unit as if the second layer is not there. Maybe it's the Verbatim's cool purple disk color? I got no idea...
Anyways so my conclusion is that it either it's the laser in the N series head unit that's not reading the disk, or the DVD decoding hardware/software not reading the other brands of burnt disk, I'm not 100% sure.
The only thing I am 100% sure of, is that Pioneer would rather you spend the $250.00 for the upgrade disk from them.
