WHEN USING BLUETOOH THE MAP SCREEN GO INTO SCROLL MODE
By HAYSUMIF · Dec 24, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,261 views
Posted Dec 24, 2007 · 21:53 UTC#1
USING MY BLUETOOTH IT CONNECTS AND I SEE MY MAP SCREEN GO INTO SCROLL MODE TO RESET IT I HAVE TO HIT MAP OR THE SCROLL MODE ICON DOES ANYONE KNOW WHAT'S GOING ON
I HAVE A Z1 UPDATE TO A Z2 WITH 60GB DRIVE EVERYTHING ELSE WORKS GREAT
Posted Dec 24, 2007 · 22:53 UTC#2
I think your caps lock key might be defective as well
Posted Dec 26, 2007 · 20:21 UTC#3
I called poineer and they told me that this a normal operation on the z2 when using the voice reg like calling a favorite
Also you wasted your time giving a answer about my keyboard
thanks alot for the forum being there
Posted Dec 26, 2007 · 20:24 UTC#4
In the future, I think you will find most forums will be more responsive to your first gripe when you are not yelling at them
Posted Dec 26, 2007 · 20:51 UTC#5
I don't know what you mean about yelling at the forum I think the forum is doing a great job I just thought the answer was a waste of your time if we need to use lower case I think we should state that in the replies
thank you
Posted Dec 30, 2007 · 14:20 UTC#6
That's normal...
You just press the Map button again, and it will go back to normal once you connect with the person you called via voice.
The yelling comment?
DONT USE ALL CAPS, that means YELLING.
Posted Dec 31, 2007 · 14:44 UTC#7
Thank you for your comment I didn't know that caps lock meant yelling sorry
Thank you
Posted Jan 14, 2008 · 03:54 UTC#8
does it go back to normal when you connect a call?
mine stays in pan mode even after the call is complete.
the only way I can get the map back to "normal" is htting the map button.
Posted Jan 14, 2008 · 12:42 UTC#9
That's what happen to mine
they say that is normal I called poineer for my answer
your machine is normal
