SIRIUS
By stx2006 · Dec 26, 2007in Problems/Troubleshooting💬 8 posts👁️ 894 views
Posted Dec 26, 2007 · 01:28 UTC#1
Ok, I have the SIRIUS turner for my D3 I was wanting to know what you guys plug the power lead into? Do you splice it into the power for the D3? Or run a whole new line to the batt? Also same for the backup cam.
Posted Dec 26, 2007 · 04:20 UTC#2
The sirius unit can be tapped into the power wire going to the D3, but make sure it's the CONSTANT power, not the switched power wire.
As for the reverse camera, I THINK you can use the wire going to your reverse light as the power source for the camera, as it only has to be powered up while in reverse. But if you want to be able to view the rear view camera at any time, you'll have to run a small power wire to it, switched preferrably, so it isn't powered on while the car is turned off.
Posted Dec 26, 2007 · 15:19 UTC#3
Thanks bro! I'mma go out here in amin and install it! :wink:
Posted Dec 26, 2007 · 23:05 UTC#4
well snap! I got the backup cam working, looks great. But the SIRIUS turner isn't working. I called up SIRIUS and they tried everything they could, so they gave me the number to Pioneer. So I called them up. The guy went through the whole install with me, and at the end said that I had it installed right. So he thinks the tuner is bad!! :(:? So now I'm trying to get Crutchfield to send me a new one. :lol:
Posted Dec 27, 2007 · 14:39 UTC#5
Just so everyone knows Crutchfield rocks! I had my Tuner since the 10th of last month and I got my D3 for x-mas. And to find out the tuner didnt work. So I called em up and they said they will send me a brand new on today! Even though I'm passed my 30 days! :lol::D
Posted Dec 27, 2007 · 15:17 UTC#6
Yeah, Crutchfield has the best customer service in the universe... Now only if their prices were a bit more competitive, I would get absolutely everything from them.
Posted Dec 27, 2007 · 15:56 UTC#7
lol.. I'd rather spend a little more to get help like that then spend less and get someone who doesn't care about you. :wink:
Posted Dec 27, 2007 · 18:52 UTC#8
the siri tuner only pulls 1amp. No problem with wiring it with your D3
