Does anyone have a pic of their D3 installed in a 06 f-150? Or the new body style of the f150? I don't think mine is sitting in there right since theres a nice gap around the unit even after I put the trim piece in there.
D3 in F150
Here's what mine looks like... It looks like it's sitting to far back???
[/img]
your pic didn't show up, but from the sounds of it you may be using the wrong holes on the mounting bracket and/or deck which could explain the spacing that you are getting. mine sits in just perfect and I also tucked the xm module under the center dash tray. tried to find you a good pic of mine, but couldn't and it's too dark outside now to. if you have any questions let me know. erik
http://img401.imageshack.us/img401/7101 ... 32aec9.jpg
I could be using the wrong holes. I'll check it after work since I'm going to wire in the VSS also.
the dash kit should have come with 1/4" plastic spacers for each of the mounting holes. You'll need those. If it didn't then you're going have have to get some from a hardware store and stick them onto the dash kit.
only thing I got dealing with mounting it was two types of mounts. one is taller then the other.. and two dash covers... which I have no clue why...
Should look like this depending on kit.
umm.. I have the trim around mine like urs. But the bottom sticks out... I guess I just need to play with it some more to see what Im doing wrong.
