problem/questions about D3 and VSS
By jimmy 2 times · Dec 27, 2007in Problems/Troubleshooting💬 5 posts👁️ 710 views
Posted Dec 27, 2007 · 17:21 UTC#1
So i just installed my D3 into an 08 corvette. I hooked up the VSS wire, (and in the calibration screen) in moves and beeps as the speed increases/decreases.
Does this mean that the VSS is hooked up correctly?
Also, it doesn't matter where I put the gps antenna on this car, I can not get better than 2 orange/green satalitte things lit up. This is wierd to me because i have the gps antenna right next to the sirius antenna (which are know pieces of junk)
I have installed a few for other customers cars in the past, and I never had problems with the GPS in this area. But for some reason in this car, i can not get a good signal. Do you think I may have a bad antenna? Speaking of the antenna, it is in a circle (not bunched up, or tightly zip tied)
Also, I am using a Scosche Kit, and the bolts are tight, but every once and a while, I am getting the excessive vibration, any cures for this?
thanks
Posted Dec 27, 2007 · 22:30 UTC#2
"Also, it doesn't matter where I put the gps antenna on this car, I can not get better than 2 orange/green satalitte things lit up. This is wierd to me because i have the gps antenna right next to the sirius antenna (which are know pieces of junk) "
Move it. They cant be beside each other. They will interfere with eachother.
Posted Dec 27, 2007 · 23:30 UTC#3
since when? In my last car, i had an N2 with the gps right next to the sirius antenna for months before i removed it. I always had full gps bars
Posted Dec 27, 2007 · 23:34 UTC#4
It can happen. Have had issues in the past with the 2 interfering with each other. Is the gps antenna mounted on a metal surface. If it's not is the metal plate it comes with being used? If no to both, then that could be your problem too.
Posted Dec 28, 2007 · 04:01 UTC#5
yes, it is on a piece of metal about 6 inches from the siri antenna. I am gonna disconnect the sirius for now, and see if that helps.
do you think I should reset the unit as well?
