speed senser wire impala ss
By impalassdude · Dec 29, 2007in Problems/Troubleshooting💬 10 posts👁️ 1,202 views
Posted Dec 29, 2007 · 21:37 UTC#1
does anyone know the colors for hooking up the speed wire and reverse in a impala ss? can the speed wire be hooked up to tach wire?
thanks
Posted Jan 06, 2008 · 05:02 UTC#2
yes, run the wire from the tach and it'll work.
Posted Jan 06, 2008 · 05:07 UTC#3
Yeah it'll work great. As soon as you start the car the avic will think you're moving. And if you rev the engine forget it. It'll think you're doing mach 1.
What year is the impala?
Posted Jan 06, 2008 · 05:09 UTC#4
its a 94...the 95,96 had it in the radio harness but 94 never had that feature.i was told it a green with white strip.but where??
thanks
Posted Jan 06, 2008 · 05:15 UTC#5
Here's what I have for a 94 impala.
Speed Sense GREEN/WHITE DRIVER FRONT QUARTER BLACK 32 PIN CONN.POS B-8
Reverse Lights LIGHT GREEN (+) AT GEAR SELECT SWITCH
My guess this is either at the shifter or the trans. If it's at the trans, then it might be easier for you to just run back to the taillights and tap there.
Posted Jan 06, 2008 · 05:36 UTC#6
thanks for the help. the black 32...is that the pcm plug?
Posted Jan 06, 2008 · 05:37 UTC#7
I would venture a guess that yeah it would be the pcm.
Posted Jan 06, 2008 · 06:34 UTC#8
i wired it to my speedometer tach and it works great.
Posted Jan 06, 2008 · 13:23 UTC#9
Ok whatever you say.
Posted Jan 06, 2008 · 14:28 UTC#10
I'm going with batman on this one.i have been told the same thing by several people NOT to use the tach wire.it will work but will not be accurate.
