AVIC-D3 on 2000 navigator... HELP!!!
By mangyan5580 · Dec 30, 2007in Problems/Troubleshooting💬 23 posts👁️ 2,771 views
Posted Dec 30, 2007 · 04:16 UTC#1
apologize for posting this topic again... I just installed my AVIC-D3 on my navigator. I did all the modifications posted on this forum. my only problem is when i turned it on, theres no sounds coming out the speakers. anyone here with the same problem in their 2000 navigator? and also i dont know where to put the speed sensor. where to find it in my car? btw, im also having problem with D3 speaker out cuz its RCA.
PLEASE HELP!!!
thank you
Posted Dec 30, 2007 · 13:50 UTC#2
speed sense is grey/black. if its not in the radio harness, go to the cruise control module on the drivers side fender
as for your speakers, are you using an amplifier?
Posted Dec 30, 2007 · 16:33 UTC#3
no i dont... im using the factory setup. i dont know if my car have amplifier or not. i checked under the passenger seat and i didnt see any.
Posted Dec 30, 2007 · 16:37 UTC#4
Posted Dec 30, 2007 · 17:33 UTC#5
Make sure that the remote wire to your factory amplifier is hooked up on your harness. In Ford Motor Company vehicles if you get the right aftermarket harness then it should have at least two factory amp wires on it. One for power and one for ground. Most people hook up that blue one during installation but not the amp ground. Now for the location.......it should be in the rear of the vehicle on the passenger side behind that panel where the factory sub is at but you should need to get to this unless you are intending to bypass. Hopes this helps
Posted Dec 30, 2007 · 18:06 UTC#6
if your not using an amp, then why would you be using the rca outputs from the avic. you should be using the speaker outputs. the only factory amp in that car is for the sub, which has nothing to do with the other speakers functionality
Posted Dec 30, 2007 · 18:53 UTC#7
i havent found it yet... but how hard to bypass the amp? do i need special harness to do that? btw, i checked my aftermarket harness and i only have ground wire for amp. i dont know if i have to connect that too and where...
Posted Dec 30, 2007 · 18:55 UTC#8
i dont know bout the amp yet... i havent found it yet. bout the RCA, i dont know what to do with that. should i just cut it so i can have the speaker wires?
Posted Dec 30, 2007 · 19:04 UTC#9
you shouldn have to cut anything. your avic should have four sets of speaker leads coming from the main power harness. if you are not using an aftermarket amp, then those are the leads you should be conncting to the speaker wires in the car radio harness.
Posted Dec 30, 2007 · 19:33 UTC#10
should i connect the amp ground wire from the harness? and where should i connect it?
Posted Dec 30, 2007 · 19:40 UTC#11
if your talking about the black/white from the metra harness, you dont need it
Posted Dec 30, 2007 · 19:48 UTC#12
got it... im gonna try and ill let youa know...
thanks
Posted Dec 30, 2007 · 20:27 UTC#13
i got it... thank god... now, bout the speed sensor... i open the panel and theres a lot of wires there. which gray/black wire is the speed sensor and on which pin? how big is the wire?
Posted Dec 30, 2007 · 22:10 UTC#14
i got everything connected and working... now, when i tried to install the head unit in the dash it wont fit... what do i need to or how to modify it?
please help...
thanks
Posted Dec 31, 2007 · 01:29 UTC#15
didnt you say in your original post, that you already installed it?
Posted Dec 31, 2007 · 03:30 UTC#16
forget the last post... i already installed everything. had to modify the bracket to get the HU fit but its working now. thank you all for helping me especially you MISFIT. i really appreciate all your help. btw, i cant find the speed sensor. i opened the panel and DAMN!!! there are lots of wires there and dont know which one is which.
Posted Dec 31, 2007 · 17:14 UTC#17
any idea how to fix insert appropriate disk error... my east dvd map is not working. i tried west and it worked.
Posted Dec 31, 2007 · 23:56 UTC#18
speed sensor location please... i dont know which one is that
Posted Jan 02, 2008 · 17:05 UTC#19
navi/ ford owners... help
Posted Jan 02, 2008 · 21:37 UTC#20
ok its the GY/BK wire at the speed control servo. pin three
The servo is mounted under the hood near the brake master cylinder
It has a cable going to the throttle linkage and a 10 pin connector
Posted Jan 03, 2008 · 03:30 UTC#21
I thought that you had already modified this opening. If you have the old style opening that requires the two keys to get it out then you will need to bore out the opening.
Posted Jan 03, 2008 · 13:37 UTC#22
i already modified the opening... the HU is running now. its just the SPEED SENSOR that is not connected.
Posted Jan 07, 2008 · 20:12 UTC#23
im still having problem locating my speed sensor...
