GPS Antenna Under Dash
By lchute · Jan 01, 2008in General💬 12 posts👁️ 6,998 views
Posted Jan 01, 2008 · 23:59 UTC#1
I am about to install my Z2 in a 2001 ML320. IF anyone has install tips for me, i would greatly appreciate it.
also..
OK, i ordered my Avic Z2, now i would like any info you guys have on installingthe GPS antennas uder the dash, where did you do it, does it work ok? how did you mount it?
i was thinking of just putting some silicone glue on the gps and sticking it to the bottom of the dash. seems simple enough.
thanks
lance
Posted Jan 02, 2008 · 03:58 UTC#2
Won't work.
GPS antenna need to have a clear view of the sky. (through glass is ok)
Posted Jan 02, 2008 · 04:38 UTC#3
I have 2007 CrewMax Tundra and I put my Z2 GPS antenna under the dash and it worked fine.
Posted Jan 02, 2008 · 04:46 UTC#4
ditto. In my 03 tahoe it is under the dash which is just plastic. Works perfect always full strength and good accuracy.
Posted Jan 02, 2008 · 06:19 UTC#5
cool, glad to hear it is working, how did you mount the antennas under there?
Posted Jan 02, 2008 · 17:12 UTC#6
I think there's actually a MB under dash GPS antenna for the older SL models. But you should have a GPS/cellular antenna on your roof towards the back, can't you use that one? You might have to order splitter or something to make it work.
Posted Jan 02, 2008 · 17:24 UTC#7
yea, i do have the antenna on the top, but it is a different adapter plug, and i don't know how to make an adapter myself for the different plugs. also, a splitter seems to be rather expensive for some reason. i originally wanted to use that antenna and put both the xm and nav off it.
Posted Jan 05, 2008 · 19:31 UTC#8
mine is mounted under the dash on my colorado and gets pretty strong signal strength.mine is mounte on the steel bar that is under the dash.most vehicles have a steel support bar under the dash.just stick it to the bar and check your signal.
Posted Jan 06, 2008 · 08:34 UTC#9
In my CrewMax I mounted the antenna under the center speaker hole. I put the antenna in the hole and used the ground plane to tape it to the hole from underneath. Works like a champ.
Posted Jan 06, 2008 · 13:39 UTC#10
Won't work.
Wrong. I have three different vehicles with the nav and the XM antennas under the dash. You need two criteria to be met. There can be no metal above the antennas, and the antennas MUST be mounted to metal. You can cut a piece of sheet metal to fit the spot (the bigger the better...within reason of course) and glue or velcro the metal plate to whatever you want. Then the antennas will hold to the plate.
Posted Jan 07, 2008 · 22:29 UTC#11
I have two Z2's. Both have the GPS and XM Antenna installed right next to one another just under the dash, close to the windshield.
The antenna's are magnetic, and in the box you will find a couple of square metal pieces. Many installers throw them away.
Be sure to attach these metal pieces to the bottom of the antenna's before mounting under the dash where in both of my vehicles it was just plastic. This will provide the antenna's with adequate ground plane.
Both of mine work great... If you don't have them, you can go to Office Depot, and purchase a 12 inch Metal Ruler. Cut the Ruler in half with some Tin Snips, and attach the antenna's to that ruler. That will provide a good ground plane as well.
I like the fact that I am not advertising I have a Nav System.
Good Luck with your install,
Keith
Atlanta, GA
Posted Jan 09, 2008 · 05:05 UTC#12
Great, thanks for the tips, i got it installed, and i found a metal bar under the dash, so i used the magnetic strip that came with the antenna, and mounted both the XM nd VAN antenna's under the dash, and they work great.
thanks![/img]
