Trouble with my Bluetooth!
By rsears1120 · Jan 02, 2008in Hacks/Mods💬 4 posts👁️ 1,541 views
Posted Jan 02, 2008 · 19:20 UTC#1
Hey guys i was wondering if any of you would know how i can solve the problem i am having with my palm treo 700p. For some reason i cannot connect my blueooth on my phone with that of bluetooth system I bought. My friend has a 650p that connects just fine but mine wont. If anyone can help me please get back to this post ASAP!
Posted Jan 06, 2008 · 04:41 UTC#2
make sure that your bluetooth is turned on which i'm sure that it is. go to the bt-telephone and press function. let the d3 search for your phone instead of your phone searching for the d3. try that first... if not, let us know what happens? good luck!
Posted Jan 07, 2008 · 16:36 UTC#3
What bluetooth system did you buy? Are you sure you have a compatible BT module?
Posted Jan 10, 2008 · 12:04 UTC#4
i have the 700p and the btb-200
do me a favor and check your firmware version
Phone... Options Menu... Phone Info...
What version software do you have?
The highest that works is 1.08... anything above that contains updated BT stack code and renders it useless to the AVIC
as far as pairing...
goto bluetooth on your phone... setup devices... trusted devices...
when it finds the avic, add it using 0000 as the password
then on your AVIC, let it find treo (since now the treo trusts it, it will let it connect) then register the phone with the avic using the register phone option (touch and hold a blank spot until your phone name appears)
to get your phonebook to the avic:
on the avic select transfer phonebook
on your treo goto contacts... make sure your view category (on the top right) is "ALL"... goto the menu and choose send category... choose bluetooth as the method
that should send your entire phone book to the avic
please post if you need more help
